SpyderLovers Founder
Way better Y-pipe gasket for 1/2 the price
I got my GL1800 exhaust gaskets today and I can tell out of the box it's going to be a better gasket. The material is much better and weighs about twice as much as the stock gasket. I received two new BRP gaskets at the same time and they were damaged when I opened up the bag. The Honda gaskets were just under 6 bucks and the stock gaskets are just under 12 bucks. The Honda gasket is just a tad longer but ID and OD are the same.
Part number for the Honda GL1800 gasket is 18392-MAM-000
Alignment Specialist
Lamont,
For those of us that do not get 'that' into the bike regarding working on it inside and out, do you think that ordering this part and taking it the dealership for service would be a good idea?...my dealership has installed aftermarket things for me without a blink in the past so they'd likely do something if I ask, provided it's not dangerous and the parts are interchangeable.
Thanks....
Also, I assume just go online and order this somewhere? Do you have a good online source?
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
Mod Maniac
Thanks to krb1945 for discovering these!
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
You should be able to get it from your local Honda dealer. I don't see why your dealer wouldn't install these as they are a much better quality gasket.
Y-pipe gasket
This may sound like a stupid question, but here goes; What is a Y-pipe gasket. I assume that it is where the two exhaust pipes join into one and then to the muffler. The joint where the two pipes join appears to be a welded joint ( unless I am missing something) and the muffler (Hindle) doesn't have a gasket. So where is the Y-pipe gasket?
WE DON'T QUIT PLAYING BECAUSE WE GROW OLD; WE GROW OLD BECAUSE WE QUIT PLAYING
Hey Lamont in the pic which is which? Thanks
Excellent. Is there one that fits the other end too?
Mod Maniac
That's a big 'un. 2.625" ID x 2.875" OD is very unusual.
My Spyder:
The one on the right is the GL1800 one, the one on the left is BRP and is damaged.
Not that I know of.
Lamont for us who do not use a gasket as we have the hindle what can you recommend to use to stop the leak at the joint, I have tried a few different high temp exhaust gasket silicone and it does not hold up for long.
Also how important is that spring that is at the joint, I have lost mine and waiting for dealer to get another one should I be worried that there is none. (lack of spring did not make leak it has been there from day one when I put on the hindle)
Lamont,
In your photo, is that blood on the floor?
Originally Posted by SeaBreeze
Lamont,
and a footprint!
I have a Hindle coming next week and I'll see if mine leaks and if it does and I find a fix I'll let you know.
Lamont,
Might be, I don't remember.
Great find. I checked mine today and they are both shot. I'll be going to the Honda shop to get these.
Awesome find!!
Going to order some to be ready when they are needed. Am thinking of wrapping my pipes ---- and will swap them then.
Speaking of which - has anyone had their pipes ceramic coated?
Now if we could just find some better bearings !
Mod Maniac
Lamont,
...Might be, I don't remember.
Can we speak to your wife? You know, just to see if she's OK.
ataDude, the CSI.
My Spyder:
ataDude, the CSI.
High temp rtv silicone
For those that can't use the gasket you can use the high temp rtv silicone. Put a thin coating on the male side of the pipe and slip it in to the female side slowly so it won't all roll up on the lip. Granted the rtv is only 600 degrees rated but if you add some fine stainless filings to the paste it will reinforce the temp standing ability and make for a stronger seal. A little messey doing it but mix it on a piece of aluminum foil and it will work every time.
Let me know how it works for you.
Ken krb1945 "Happy Owner"
USN DAV 100% 'er
Proud grandfather of a former United States Marine
1 2008 SM5 PE 548
1 2008 SM5, 1 2009 SE5
2008 GL1800
for the big end gasket
If some one will pm me the measurements I think I might have a real good solution for that one too! I'll be out of pocket for 3 or 4 days so don't expect the post for a few days.
USN DAV 100% 'er
1 2008 SM5 PE 548
2008 GL1800
Mod Maniac
2.625" ID, 1/8" thick... 2.875" OD.
My Spyder:
Y pipe gaskets
I'm after a pair of these. I rang my local Honda shop in Sydney (Aus) and was told they were $27 each. Ouch!
Would someone be willing to put a couple in the mail to me and work out the cost say by Paypal?
Cheers;
Pogo.
PoGo...
I keep 10 to 20 in the cabinet all the time. I just got 10 fresh ones in stock. Send me a pm with address and quantity that you wish. Also be advised these that I just got cost me $8 with tax. I was told by dealer that honda had just raised prices 15%. Last ones I bought 3 months ago were 6.50 and tax. Just reimburse me for the 8 I paid and shipping.
Also do you need any relays? I have the small and large units. Borg warner types and they are 30/20. Small ones cost me 9 and the big one was 17. Let me know. /Ken
USN DAV 100% 'er
1 2008 SM5 PE 548
2008 GL1800
Tags for this Thread
