Results 1 to 5 of 5
    Feb 2020
    Phoenix, Arizona USA
    Spyder New Member with questions?
    Thank you so much for welcoming me.
    I am on here because I have several questions, but I am not sure if I will get any answers from anyone.
    I have a 2014 Can-Am Spyder Limited ST. It is Cognac (same color as the state of AZ on the above map) in color.
    I just recently changed the front brake pads on my Can-Am with a little help from my husband, even though I did most of the work myself and for the first time as well.
    My first question is, how do I change out the rear brake pads on my Can-Am?
    This is something that my husband is going to help me with doing so that way we know how to do it in the future and not have to worry about taking the Can-Am into the Motorsports Dealership where we got it from in April of 2018.
    Second question, do we need to take the rear tire off of my Can-Am to replace the brake pads or what do we need to do?
    Third question, Do we need special tools to do this job?
    Fourth question, Where do I get the tools that I need to take the brackets off of my Can-Am that hold the hard cases on the back of the Can-Am?
    The bigger bolts that are at the top, front of the brackets are triangular in the middle, with the outer edge being circular.
    I know that there are other bolts or screws that need to come off as well.
    This is not only to use when changing out the rear brake pads, but also when my husband needs to change out the bulbs for the brake lights.
    Is there anyone on here than can help me out?
    I am in dire straights here. My rear brake pads are squeaking horribly bad.
    The squeak is loud enough that my husband could here it all the way up our street back on Saturday when I came home from being out for several hours earlier in the day.
    I can even hear it through my helmet that I wear with ear plugs in my ears when I am coming to a stop at a stop sign or red light.
    Please help if anyone on here can.
    Thank you so much in advance!!!!!!
    Florida Swamp
    Look for a video on U-Tube about changing the brake pads. There should be one.
    2019 F3-S , Black & Silver
    May 2016
    Tombstone Az
    Not an St but the procedure is similar.
    https://www.youtube.com/watch?v=iKg7mScwKbg
    Also look here https://www.spyderlovers.com/forums/...pads-replacing
    The tool to remove the bags should have come with the bike On mine it was in a plastic bag.
    https://www.spyderlovers.com/forums/...n-Am-Givi-bags
    Oct 2017
    Central NJ
    Bossier LoUiSiAna
    Yes bag tool should have came with bike & vendor on home page BaJa Ron has brake parts & special tool that will help. Hopefully the pads are not metal to metalbut Ron has parts for that too. https://www.spyderlovers.com/forums/...rs-amp-Helmets
    No the rear tire does not need to come off but removing the bags may help here a copy of instructions from Ron:
    Spyder rear caliber :
    instructions from BajaRon
    "Rear pad install
    The rear caliper also serves as the parking brake the rear piston needs to be retracted as the fronts with a C-clamp.however, it is likely that it will not retract far enough to complete the install. You will see 2 holes in the top of this piston bag for inserting a tool. The rear piston must be turned CLOCKWISE to retract the parking brake system. It is best to clean the rubber piston boot before this step it may take a good deal of force to start the piston turning but should get easier once the piston begins to turn. Turn the piston until it bottoms out.”
    & a pic of the bag tool:IMG_2646.jpg the pin making T can slide might look like a L or just be not even. Additionally Squared Away also on home page in your area & quite helpful at these problems
    https://www.spyderlovers.com/forums/...Away-Alignment
