Results 1 to 25 of 29
    Active Member Hokiev's Avatar
    Jun 2011
    Indian Land, SC (30 miles S of Charlotte, NC) was Spotsylvania, VA
    Default Rear tire removal
    CORRECTION - SHOULD Have indicated 36 mm not 37 mm. Thanks for the correction.
    For those who have tackled removal of the rear wheel on a 2015 RTS to replace the tire, did you use a 37mm wrench or socket to remove axle bolt? I would prefer not to have to purchase both if it can be avoided.
    HokieV
    2015 RTS Intense Red Pearl (New Jan. 2016) - Comfort Heated Seat w/Backrest, Custom Dynamics HMT Brake Light, superbrightled.com Brake Light Strobe, TricLED fender lights w/Blinker Module & Turn Signal Strips, Stebel Nautilus Horn, FOBO TPMS, Spydercuff, Dual USB outlet, Bike Barn.
    Previous - 2011 RT Limited.
    SoFlo
    Quote Originally Posted by Hokiev View Post
    Not to nit pick, pretty certain it is 36mm. I use a long breaker bar and socket, on the exhaust side. Forget what I use on the pulley side.
    Northern Kalifornia
    Yea, 36mm. Socket on one side wrench on the other. Use socket and torque wrench for final tightening. 36mm will also fit oil filter. Different years call for different torque on rear axel.
    Feb 2012
    Spring City,Utah
    It is a 36mm. You can use just a socket and ratchet to take it off, but you will need something to hold both sides to get it tightened. If you look on the internet these tools are not expensive, and you will use them. I think I got mine from Summit Racing for the wrench. I already had the socket, a Mac which I bought 45 years ago.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2012
    Stetson, Maine
    If you can not find a 36 mm socket or wrench, you can use a 1&7/16 inch wrench, works great. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Buy a 36mm box end / open end wrench and cut in half, problem solved
    2008 GS.....PE # 2888
    Harrington, Australia
    You have a 15RT? That is a couple of years after CanAm upped the torque settings for the axle bolt. It is around 160 ft/lbs. (pre 2013 they were under 100). You’ll need some decent leverage to break it free, and a decent torque wrench to re set it.
    HeliBars Handlebars
    Kenda Kanine rear.
    Quote Originally Posted by Big Arm View Post
    Do you have a post 2013 model, Big Arm? Trying to get up to 160 torque is a real issue without a big torque wrench on the post 2013 models.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2008
    I have the '08 GS, so have to snug mine real tight
    Get this baby! You can then use a 1/2" 120 lb-ft torque wrench to easily get the 160 lb-ft torque needed for the axle nut.
    https://www.amazon.com/Torque-Adapte...7579322&sr=8-7
    USA
    Mr. Hokiev,
    Mine is a 2018 RTL, but the info may be the same, depending if the axle nut is a tight fit to the muffler.
    I use a Kobalt Metric 1/2-in Drive 12-point 36mm Shallow Socket P.N. 338135 for $8.98 (Lowes). It's short enough to get between the muffler and the axle nut on my RTL while mounted on a torque wrench. It's 12 point but does the job.
    I also use a Sunex 936 36-MM Jumbo Combination Wrench, CR-MO, about $20 on Ebay.
    You'll need a 1/2" torque wrench with the appropriate range. Remember, if there is any lubricant on the axle thread you must reduce the torque by the correct amount based on which lubricant is used. These values of torque reduction can be found on this internet. Use at your own risk.
    If you don't have one, a Krikit II is a must for setting the belt tension correctly. Removal of the rear wheel, even if done taking all precautions to not change the adjuster setting is a 50/50 proposition (In my estimation). For me, a lot of times, the belt will have to be readjusted to run on the pulley in the proper position after wheel removal in installation.
    h0gr1der
    Jul 2019
    UK
    You'll need both. One to tighten/slacken with and one to hold the opposite end of the axle with.
    I'm not sure why buying both is an issue for you but a deep socket is a cheap and common item at a motorfactors store. You could do this as shown below. Buy a deep socket and cut it in half then tack on a handle. I carry them with the Spyder along with an extendable breaker bar, commonly sold for removing wheel nuts, so I can deal with front or rear wheel removal on the road if necessary. They live in the front trunk.
    Also, when slackening or tightening the axle, you do not need to squeeze the socket and torque wrench between the silencer and the axle, tighten from the sprocket side and hold the nut still with the wrench. Easy access.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Sep 2014
    USA
    I would only torque from the nut side when putting it back together.
    Jul 2019
    UK
    Why? The forces are equal and opposite except for the tiny drag of the axle.
    Quote Originally Posted by PinkRosePetal View Post
    My experience is that the friction between the head and mating surface is greater than between the nut and mating surface, thus affecting the torque required to tighten the nut. I think it's because of the presence of the washer and any lube on the washer. I do tighten from the head end until the final torquing.
    Really, this must be an " other side of the pond thing " ….. every good mechanic I ever knew removed the Nut from the bolt or shaft, unless there was no other way of dis-mantling ….. good luck …. Mike
    Sep 2014
    USA
    I would agree with post #15 stated . Another would be trying to achieve 166 ft LB from the axle side, IMO would twist that hollow axle at some point. There is less friction on the nut side when torqueing the axle nut.
    https://www.boltscience.com/pages/wh...-bolt-head.pdf
    Jul 2019
    UK
    I understand your thinking but in the Spyder axle application it's not really valid. If one end of the axle were completely bone dry and the other end lubricated then there would be a difference in the friction at the axle head compared to the nut/washer interface which may be significant but if you've correctly assembled the axle and its components then there will be a considerable amount of lubricant at the head end of the axle because of the wiping action as the axle is inserted. Failing this, a dab of grease at the head would do the job equally well. If you've correctly aligned the components before the insertion of the axle there will be very little rotational drag.
    However, if you feel more comfortable applying the torque to the nut you should continue to do that.
    Jul 2019
    UK
    Perhaps you missed this quote taken from the article you link to:
    "...it will not matter whether the bolt head or the nut is tightened.
    Some people believe that by tightening the bolt head rather
    than the nut it will affect the torsion in bolt shank. The torsion
    in the shank of the bolt depends upon the thread friction
    torque. For a given finish condition, the thread friction
    has some scatter associated with it, but will not depend
    on whether the nut or the bolt head is tightened. If the thread
    friction torque remains the same, the torsion in the shank
    will be the same irrespective of whether the bolt head or the
    nut is tightened."
    As for shearing the axle shaft, simply not even close.
    Jul 2019
    UK
    I think we're discussing tightening the axle nut.
    Sep 2014
    USA
    Well lets all say its a 36mm nut That's what the OP was asking anyway.
    Nut side , axle side , whatever works for you is fine with me.
    USA
    I've done it both ways, and pulling on the nut side while pulling the wrench towards you will almost always result in the axle shifting and the belt running out of alignment. I now use a small ratchet strap on the right non drive side to pull the axle forward to keep the adjusters seated, the belt tension keeps the left drive side adjusters seated, and tighten the nut pushing up on the torque wrench. What a pain in the rear!
    h0gr1der
    Northern Kalifornia
    Yep, tightening forces in the rearward direction toward the belt adjusters, otherwise you'll change the belt alignment. With the rear wheel off the ground and the spyder secured, start it up and put it in first gear. With the wheel spinning while torqueing the axle you can watch the belt walk across the pulley. 166 lb. torque is way over reasonable. JMHO though.
    Jul 2019
    UK
    Quote Originally Posted by h0gr1der View Post
    Yep, I'm with you on that one. But my technique is slightly different, I nip up the axle tightening on the sprocket side, quite firm but not rigid tight. That little spanner tool I made, shown in the picture a few replies back, is on the silencer side and I give the end of it a couple of whacks with a hammer to ensure the axle and right adjuster is firmly seated forward then finally tighten the axle to spec. Works for me.
    Jul 2019
    UK
    ... 166 lb. torque is way over reasonable. JMHO though.
    Agreed...
