Results 1 to 22 of 22
    Oct 2019
    Havana, FL
    Default F3 oil change for less than $50
    After recovering from the shock of seeing the price of an oil change kit on Amazon for $101, I did some research and this is what I came up with.
    Since the consensus seems to be to go with Rotella T6, this is what I am going with.
    Walmart - 6 gallons for $116.29 - $125 with sales tax.
    Ebay - HF556 oil filters - if you buy 4, $63.60 with shipping.
    These items will give you 4 oil changes, with 2 quarts left over. For the 5th oil change, just buy 1 gallon of Rotella for a little over $20, and another filter.
    For the 4 changes, it works out to $47.15 per change. ($125 + $63.60 = $188.60/4 = $47.15)
    The 5th oil change will be less than $40, since you have already paid for 2 quarts of oil!
    Seems like ANYTHING for the Can Ams are dearly priced!
    2019 F3L , LAMONSTER BRAKE ROD, LARGE PEDAL ORANGE
    Quote Originally Posted by alchaz View Post
    RE-BATE available until 12/31/19 …. on-line for Farm stores ….. however I would try it anyway since you already bought it …. go to the Shell re-bate web site and check it out ( it's a substantial $$$$ ) ….. good luck …. Mike
    Apr 2019
    Clinton, MS
    Don't forget to add in the o'rings and washers.
    Just had an eye opening experience at my local dealer. Carried my 19 RTL in for it's first service and after waiting a week decided to pick it up and do it myself. Got the oil, filter and o'rings from them. Drained the oil and removed the filter. cleaned everything up and started to reassemble only to find the only o'ring I had was the large one for the oil filter top.
    Retraced my steps all the way to the dealer thinking I dropped them or left the on the counter. Nope. They don't stock them. When they change oil they just reuse the old ones. Would I like for them to order them? Nope, that is what the internet is for from now on.
    Mar 2013
    You can save even more by purchasing your oil filters from BajaRon as he includes all the O-rings and washers needed with the oil filter. I use his Hiflow ones at under $14 per each (4 sets for $49) as well as the T6 oil that I purchased at Walmart and with the rebate it came out to less than $4 per quart.
    So mine are at less than $38 per change.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Apr 2019
    Florida Swamp
    Mine averages around $65 - $70 per oil change, but I have bought bulk packs of the sealing washers, o-rings, and filters. I order the 6 or 12 packs of the oil I use from Amazon any time I notice it is a few dollars less than it usually is, Got enough on the shelf for the next 3 or 4 oil changes now.
    The cost of an oil change is not even something that is on the radar after you pay $20 to $30 grand for a bike.
    2019 F3-S , Black & Silver
    Feb 2012
    Spring City,Utah
    I buy my filter kits from BajaRon, all the washers and O rings are there. As the washers are not crush washers but simple copper ones, if not damaged you can re use them. But they are so cheap why not? I have enough oil on hand of the 3 brands I use to do 14 oil changes. 4500 miles/change that means I'll have 116000 miles on the Happy Dragon before I run out of oil. That should get me thru the next 5 years.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Gwolf View Post
    But saving $200 to $300 buy DYI, goes toward offsetting that initial expense.
    I wouldn't be concerned about the old washers ….. I've done 10 oil changes ( 1330 ) with the same washers ….with no leaks …..Mike
    Sep 2009
    La Valle, WI
    I buy 1 oil change at a time. I have a tendency not to keep the same bike very long. Bad habit I guess.
    2018 F3 Limited , Oxford Blue
    Jan 2017
    Vancouver, B.C.
    Looking at these HF556 oil filters, do they come with o-rings.
    2016 F3 Spyder Limited SE6
    2005 Honda ST1300 ABS
    Apr 2019
    Florida Swamp
    Quote Originally Posted by Al Gully View Post
    The kits should have the o-rings with them. You can buy the filters without the o-rings. You will have to read the product description to be sure. It all depends on where you get them from.
    Apr 2019
    Florida Swamp
    I am using some washers with neoprene or some damn thing sandwich bonded style construction over a thin metal washer. Don't even remember where I got them from. I think it was Amazon. They are the OEM drain plug washers for some metric car. I got bulk packs of about 50 or both sizes. They don't need to be tightened very tight and it is easier to loosen the drain plug using them instead of the solid metal washers.
    Here it is........... I knew I wrote it down somewhere.
    Rubber composite drain plug washers in many different metric sizes.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Apr 2019
    Clinton, MS
    How about the o'rings? Got 10 oil changes on them also?
    Apr 2019
    Florida Swamp
    The Baja Ron oil filters come with the o-rings.
    Oct 2019
    Havana, FL
    All o-rings and washers are included with the filter.
    Oct 2019
    Havana, FL
    Rebate ends Dec. 31,2019!
    Yes, ….. I lump all washers / oil rings etc. into one category …. " Seals " ….. sorry I should have been more specific ….. Mike
    Apr 2019
    Clinton, MS
    Well, guess the quality of the o'rings has improved a bunch over the years. Still can't believe they didn't even stock them.
    Mar 2013
    Marion, Arkansas
    I understand that everybody wants to save some money but you got to understand you've made a very pricey investment in an expensive motorcycle and it needs to last many years and miles. So why not treat your Spyder like a Queen and give her the best. I personally buy my filters and oil from Baja Ron and I only use Amsoil in mine. I think it is the best oil and has proven to be great from all the oil analizes I have seen. Just my 2 cents
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Dec 2019
    Land of Lincoln
    A 50 dollar (synthetic) change is possible, but you have to be on the lookout for bargains.
    The OP figured it out with Rotella, there are other options that can put you at the magic 50 dollar mark.
    Recently, AutoZone closed out Castrol Power 1 for 2.00 a quart, so easily done there.
    WalMart com has Valvoline Full Synthetic MC oil at 42. for 6 quarts with free shipping.
    Amazon has Triax Xterra MC oil at 39.99 for 6 quarts and free shipping.
    You can always go to a conventional oil and be less than 50.
    Valvoline conventional MC oil, 4.57 at WM.
    Mag1 semi syn MC oil at Grainger, for a little over 4. (And contrary to common thought, that's a stout oil, and shows excellent used oil analysis with minimal wear.)
    From what I see, BajaRon has a really solid deal on filter and seals.
    Dec 2019
    Land of Lincoln
    https://www.walmart.com/ip/Quicksilv...hoCPREQAvD_BwE
    Quicksilver 10w40 full synthetic on sale at WM. 6 for 27.73
    Aug 2019
    Stoughton, WI
    Back in early fall of last year, my local Walmart had the Quicksilver on closeout for $2.50/qt Seeing good reviews on BITOG, I bought the remaining (3) quarts.
    2022 RT Sea To Sky
Tags for this Thread
