Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 109
  1. #26
    May 2018
    Chateauguay, Qc, Canada
    I have just had a quick read of the method used by the Aussie fellow and he makes mention that he measures the rear wheel at the rear most point. This is insufficient to know the orientation of the wheel in the horizontal plane. You need to measure a second point, preferably at the front most point of the rear wheel. to determine its orientation. Once you have determined the orientation of the rear wheel you can proceed to align the front wheels parallel to the rear wheel or at a specific desired angle to the rear wheels.
    It may be that the alignment of the wheels is sufficiently insensitive that an approximation of parallelism based on one longitudinally measured point on the rear wheel is sufficient to improve the alignment to a point where it feels better to drive but it is insufficient for accuracy.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
  2. #27
    SoFlo
    Quote Originally Posted by Eckhard View Post
    Also, the method shown, accounting for camber will not provide an accurate reference datum for the alignment.
    Consider, they suggest a machinist square to reference the left and right datum points. Unfortunately, any toe in or toe out at this critical measurement will alter the points projected to the ground. Add to this, the variance / tolerances at each measurement and some precision is surrendered.
  3. #28
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    How do you reset the BUDS?
    I have BUDS. You need it to reset the steering angle offset, etc.
    2020 RT Limited , Marsala Red
  4. #29
    Feb 2016
    Does this align to the chassis or to the rear wheel?
    To the rear wheel, which is better if you already have your belt tracking right.
  5. #30
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Jetfixer View Post
    That was my point. Not everyone realizes this.
    2014 RTL Platinum
  6. #31
    Feb 2016
    You're right about the front datum points possibly being way out to start, which would completely affect the rest of the process. This would be the case if you were trying to use this method after having incurred some damage to the front end like a bent tie-rod. Also if the belt tracking was way off you could assume that the measurement at the rear wheel would throw everything else off too. This method assumes that the Spyder is already at least factory aligned and has the proper belt tracking at the rear wheel. Using that as a starting point, (which is how most of us have had our Spyders laser aligned), this method does a very good job of providing the final adjustment needed to get the better handling of a truly aligned front end. For even better accuracy, you could also project the "alignment box" forward from the front wheels which would double check the adjustment.
  7. #32
    SoFlo
    Politely, I beg to differ. As you and I are both jet fixers, consider my words. If, the Spyder has toe out prior to alignment, the laser point projected to the square will not be the accurate track width, plus laser and fixture. Add to this, the machinist square uses a small base, that amplifies error as the square may not be truly square on the floor.
    The ROLO setup, uses a laser fixtures that swivels to project downward, eliminating the error induced via incoming toe settings, and the machinist square transferring a point to the floor.
    Both methods are working to obtain the same reference datum points.
    Your setup uses pie plates on stanchions. If the stanchions are each exactly the same, the pie plate runs true in plain without runout if the wheel could be spun. (The brake caliper prevents this). Possibly your setup could point the beam down, similar to ROLO, and would allow you to compare the two methods for accuracy. Downside to this being, if you have already established accurate toe setting, that error is eliminated or reduced. Whereas, the swiveling setup has no care of incoming toe setting.
  8. #33
    May 2018
    Please tell us more about the pie plates?
    Eckhard
    Spyder RT Ltd, 2011
  9. #34
    SoFlo
    The Aussie method has you make large circular round flat plates. These are on standoffs that are measured and adjusted very accurately, The standoffs, flat circular plate and brake disk establish the mount for the laser.
    Since the circular flat plate is rigidly secured to the disk by magnets, there is no easy method to obtain an accurate / true track width, which is the basis for all other parameters.
    As the Jetfixer mentioned, if the alignment is very close already it could work ok. On a never aligned machine, it appears a bit risky and less accurate.
  10. #35
    Feb 2016
    I agree with you except that if either method (Rollo or Aussie) points the lasers down, now you have to account for the factory set and unchangeable camber. Since the Aussie system uses magnetic laser line generators, they can be pointed down even though the plates cannot be moved due to the caliper. When you have the time, read the alignment info post here: http://www.lindsayroland.com/spyder/spyderwheels.html that is written by the guy who devised this setup. He mentions his system versus Rollo and Lamonsters'. I had my 15 RTL laser aligned and then compared my homebuilt setup with what was done. It's pretty much dead on with what the Rollo system set. This system is not perfect, for instance, I made a set of greaseplates instead of his newspaper setup. Far less resistance to adjustment.
  11. #36
    SoFlo
    I had read the linked topic a few times to grasp each step, and what the method stated was working to achieve.
    Someday, when time permits, I will check the camber angles, Left vs Right, laden and unladen, then see how they compare.
  12. #37
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Since I do all my own work, I built my own laser alignment system, based on plans found here, with some modifications. http://www.lindsayroland.com/spyder/...-DIY-gear.html
    I made my own laser set up also. Did my Spyder 6 years ago when I purchased the bike. I’ve been through 3-4 rear tires (obviously lol) but still on stock front tires which are wearing perfectly. With a few measurements and two cheap lasers it wasn’t hard at all.
  13. #38
    Nov 2016
    Upstate NY
    I am also going to check mine the next time I do a laser alignment. I assumed, but shouldnt have, that the camber was zero. If it is not zero, then not only will homemade laser alignment tools be inaccurate, but ROLO will be also. Ideally, you would need a device that attaches to the hub with a level on it to ensure accurate track width measurement when the laser is pointed down.
    2021 Sea to Sky RT , Highland green
  14. #39
    SoFlo
    Yes and no. If the camber angle is equal or merely close, the error projecting from axle center downward to the floor is a very small error.
    There is more chance for inaccuracy based on assuming toe angle / dimension is equal left and right.
    Regardless, either method is no doubt better than oem.
  15. #40
    Idaho
    Why do you need the track width at the wheels? The concept of the ROLO is to mount the laser on the center of the wheel, then project the laser to the front and to the back. The toe-in is measured by the difference between the left and right laser points an equal distance in front of and behind the wheel centerline. Since the lasers are horizontal for both measurements camber does not affect them.
    2014 Copper RTS
  16. #41
    SoFlo
    Yes and no. Your words about projecting forward and aft are correct. The track width measurement is needed to establish the distance between targets at the 0.0 point. Without that, there is no reference of what zero toe will be, and no ability to establish / set the correct toe.
  17. #42
    Jul 2019
    UK
    If the lasers are parallel to the ground, a target placed in front of and square to the vehicle alignment centre, can be marked at the laser dots. If the target is then moved by the required toe distance (wheel rim diameter for me) then the difference between the dot spacing on the target equals the toe distance.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
  18. #43
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by PinkRosePetal View Post
    Exactly correct!
    Joe Meyer
  19. #44
    Idaho
    You will have zero toe when the distance between the laser beams on the front targets equals the distance between them on the rear targets. But rather than adjusting the tie rods you do it arithmetically. If the beams are 1/2" closer in front than back then zero point would be a 1/4" wider in front and 1/4" narrower in back.
    2014 Copper RTS
  20. #45
    SoFlo
    Humor me, in Lamonts video, he discusses the first step using the lasers, after tire pressures and if needed belt alignment.
    At around 4:40 into the video he begins by measuring track width plus tooling. Followed by, setting targets and rotating lasers horizontal.
    https://m.youtube.com/watch?v=2fs8bI3b_BA
    This IMotorsports video, also shows them measure track width plus tooling.
    https://m.youtube.com/watch?v=WoOyAvShZ9I
    This video by Shawn Smoak ido not see him measure track width. Possibly his video format omitted it, but if an alignment can be done without learning what true zero is, I would enjoy hearing how that is possible.
    https://m.youtube.com/watch?v=cQ89O379Ljw
  21. #46
    Apr 2019
    Clinton, MS
    [QUOTE=PMK;1490305]Humor me, in Lamonts video, he discusses the first step using the lasers, after tire pressures and if needed belt alignment.
    In most of Shawn's videos from work you do not see a step by step process. May be a requirement of his employer.
  22. #47
    SoFlo
    Very possible and my linking his video is no disrespect to him or the shop he works at. As best I can tell, and he is a continent away, Shawn is one of the true GoTo Spyder techs.
    As I mentioned too, very possible his editing the video omitted that portion.
  23. #48
    SoFlo
    Fair enough, but what reference are you using to establish where to place the targets?
  24. #49
    Feb 2016
    The laser pointers do have levels on them.
  25. #50
    Feb 2016
    http://www.lindsayroland.com/pdf/Spy...gnment-Kit.pdf
    This is the step-by-step process for doing the alignment.
