Results 1 to 25 of 25
Thread: Brake Pads
    Dec 2014
    Graham Tx
    Default Brake Pads
    Is there any recommendations for brake pads on my 2017 F3L?
    Is draining the brake fluid something I can accomplish at home
    or does a spyder shop have to hook up electronics to get everything
    walking and talking?
    Dray
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    If you wish to change brake pads get them from BajaRon, a site sponsor. He sells the EBC fully sintered brake pads at a fair price. Best brake pads you can get. You can also drain the brake fluid yourself. You don't need BUDS to do it. The only thing that BUDS does is drain the small amount of brake fluid from the ABS module.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Good advice.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Aug 2019
    Stoughton, WI
    If you're just changing pads, you won't need to bleed/flush your system. Will be a bit easier to compress your brake pad pucks by having the res caps off. Use lots of towels around the reservoirs...
    2022 RT Sea To Sky
    Sep 2016
    LI NY
    BajaRon
    2010 RTSM5 , stock Stock Silver
    Mar 2013
    When changing the rear pads. Make sure the parking brake is off. The caliber piston has to be turned in using a needle nose pliers, or the tool that Ron sells. Do not try pushing it in like you can with the fronts. I opted for Ron's socket as that made the task a lot easier.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Or just drain it a bit at a time with a turkey baster or vacuum tool to keep it from overflowing as the caliper pistons are retracted....
    Chuck
    Feb 2019
    Portland, Oregon
    I install Speed Bleeders on all my vehicles. The difference is they have a built in check valve where regular one do not. The check valve only allows outward flow of the brake fluid. And the make the task of bleeding stupid easy - and a one man job. I get the best bleeds since I started using Speed Bleeders.
    The procedure goes like this after you installed Speed Bleeders:
    + Carefully remove the reservoir cap. It will have brake fluid on it, so have towels at the ready.
    + Using a suction device, such as a baster, draw out all the old fluid. I use a large hypodermic syringe I got after an injection - they just toss them out. That works really well.
    + Carefully fill the reservoir with fresh DOT4 fluid. I cut a small triangular opening in the seal to better control the flow.
    + Attach clear tubing to the bleeder and place the other end in a catch container. The heavier the container the better.
    + Open the bleeder 1/8 to 1/4 turn.
    + Press the brake pedal slowly and do it often enough that you can see clear fluid in the tube.
    + Close the bleeder and remove the tubing, you are done with that caliper.
    Order Speed Bleeders direct from speedbleeder.com and it is best to phone your order in so you get the correct ones. They run @ $7 each and shipping is free.
    Sep 2013
    Houston
    The fluid is to be flushed and bleed every two years anyway. When doing pads is the perfect time to get the brake fluid flushed as well. We never do one without the other unless it was just recently flushed which is pretty rare as we would have noticed the thin pads at the time.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2017
    Quote Originally Posted by PW2013STL View Post
    Yes. If you don't know, the beeper that warns you that you did not put on your rear brake goes silent about 30 seconds or so after you turn off the key so you can leave the brake off to remove the wheel. The rear caliper piston does "screw" in and a brake tool will do you little good getting it to compress if it's too far out. When I did mine, I used a dowel rod and a hammer to push it in far enough to get the threads to engage. I do know that I will never again let the rear pads get so worn that the piston threads will not engage.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Rattlebars View Post
    A good lesson learned. Another reason to change at the halfway mark. Pads are cheap enough not to skimp on them.
    Mar 2017
    Quote Originally Posted by JKMSPYDER View Post
    Can't find pads on Baja Ron's Facebook market. I did buy the piston tool for cheap with free shipping.
    Feb 2012
    Spring City,Utah
    Try this: Call him for prices. Use his ad on the home page here to find things. He also sells lots of other accessories.
    EBC Fully Sintered Brake Pads - 2013-2019 - All Spyder Models with Brembo brake systems.
    (Includes Domestic Shipping)
    Stop Better - Last Longer - Quiet
    Front Brake Pad Set - 35.95 (You need 2 sets)
    Rear Brake Pad Set - $35.95
    Full Set = $107.85
    These pads will not work with 2012 or earlier model Spyders.
    Rear Caliper Piston Retraction Tool $14.95
    This handy little tool fits on the end of your 3/8" Drive Ratchet or Extension. When replacing the rear brake pads on you 2013-2019 Can-Am Spyder, you must turn or screw in the rear caliper piston to make room for the new pad set. This little took makes the job much easier. The 2 pins fit perfectly into the corresponding holes on the rear caliper piston so you can turn it.
    2013-2019 EBC High Carbon Brake Rotors - All Models (Includes Domestic Shipping)
    Front Rotors - $94.95 (Must be replaced as a pair - You need 2)
    Rear Rotor - $139.95
    Full Set = $329.85
    It is not required to replace the rear rotor if you install EBC rotors on the front.
    These rotors will not work with 2012 or earlier model Spyders.
    EBC Rotors are made from a special Heat Treated, High Carbon Content Stainless Steel giving 20% more friction (stopping power) than OEM rotors. Specially formulated steel compound is highly resistant to warping and wear.Though the use of EBC Rotors will increase stopping power, reduce fad and resist warping and wear better than the BRP rotors. It is not necessary to purchase EBC rotors when replacing the brake pads. EBC Brake Pads will work fine with the stock Spyder rotors.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2019
    Portland, Oregon
    From where did you buy the tool?
    Feb 2012
    Spring City,Utah
    Ron also has the tool.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Aug 2007
    Greeneville, TN
    You can always get me at fyredad@hotmail.com
    I don't list everything on the Facebook store yet.
    Feb 2019
    Portland, Oregon
    I have a snap ring pliers with 90* tips - would that work?
    Mar 2013
    It should work, but you will have very limited travel with that.
    Feb 2019
    Portland, Oregon
    I have no idea what that piston twister looks like, can someone post a photo?
    Mar 2013
    Here is a picture from Ron's page. As you can see it has the two pins that fit into the piston holes and attaches to a 3/8" ratchet. This allows you to push in as you turn it. Works great!
    Sep 2017
    Durham,Maine
    You can get one of those at any auto or harbor freight stores!
    2012 RTL , Pearl
    Mar 2013
    Maybe, but when I rented a very complete brake retraction tool set from a auto parts store not one of the many sizes in that kit fit the pin spacing of the Spyder piston.
    If you get the pads from Ron you might as well get the tool that does fit.
    Apr 2019
    Clinton, MS
    The ones at Harbor Freight do not have the right pin spacing.
    Aug 2007
    Greeneville, TN
    Snap ring pliers can work and have been used. People have also ruined these pliers trying to turn the caliper piston in because they are not that strong. It all depends on how stiff your caliper piston is. It helps to put pressure on the piston as you turn it, which can be hard to do with snap ring pliers.
    I am not saying there are no tools out there that fit the pin size and spacing for the rear caliper piston. But I was not able to find one readily available. That's why I made this tool. It's not pretty, but it is simple and works really well. Just be VERY SURE you turn the piston CLOCKWISE! Those who have turned them the other way have regretted it.
    Feb 2019
    Portland, Oregon
    I'm convinced. When it's time to replace pads in the rear, I'll be buying those and the tool from BajaRon. Thanks all for showing me light.
