Results 1 to 21 of 21
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    Default 2019 RTL front storage light?
    So - I've been reading my manual for my 2019 RTL and on page 156 in the Specifications section it says that the front storage section has a 0.2 W light.
    I have searched high and low for this light and can not find anything - anybody else find this?
    2019 RT Limited , Asphalt Grey
    Jul 2016
    australia
    hi there,i have a 2014 rt ltd which has a light in the front,if its the same its on the left side of the trunk kind of hidden behind the carpet liner.i couldnt find mine at first either
    its pretty useless though,i carry a led torch
    INDIANA, USA
    Default Frunk Light
    It should be at the left side (when standing at the front of your Spyder).The light is not very bright. I carry a little LED Flash Light in my frunk. ....
    ENJOY YOUR LIFE WITH A SPYDER
    SoFlo
    Regarding the light, our 2014 has the light. As other mentioned it would be on the Spyders true left side if facing forward.
    Sometimes the interior upholstery can block the light.
    Other times, the owner does not realize that either key must be in the on position, OR the light will operate during that 30 second shut down time after the engine is stopped. When the headlights go out, the frunk light goes out. Saying that, I find it easier to let the headlights illuminate the frunk.
    In the rear trunk, there is no light. Others have posted various methods, either battery powered with replaceable batteries, or powered by the 12 volt round power plug if equipped. On ours, a while back, I utilized two BRP Spyder front frunk lights and wired them to use the same circuit as the front. Slight pain since the frunk lid must be open to operate the light switch and as mentioned before, the key must be on. At first this seemed a hassle, but most times it is not. Plus, we get a lot of light in the trunk with those two lights and it takes up no interior space at all.
    ...Sometimes the interior upholstery can block the light.
    Other times, the owner does not realize that either key must be in the on position, OR the light will operate during that 30 second shut down time after the engine is stopped. When the headlights go out, the frunk light goes out. Saying that, I find it easier to let the headlights illuminate the frunk...
    What he said!!!
    Feb 2019
    Portland, Oregon
    Every time I buy something at Harbor Freight I get one of their free flashlights. Now there is on in all 4 cases.
    Clinton, MS
    Short of ripping all upholstery away from the tub I am confident my 2019 RTL does not have a frunk light either.
    Nov 2019
    SE Pennsylvania
    Thanks EdMat - I thought I was losing my mind! I can't find that light.
    Sep 2014
    USA
    Yeah that frunk light is useless. I took a strip of LED light with sticky backing and put it on the rear of the frunk liner. Then ran the wires to the frunk light. I used a plug and play adapter I made up.
    So it operates the same way and I can see in my frunk.
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by Snakeyes View Post
    I owned my Spyder RTL for 2 years before I found/realized there was a frunk light. When it is on, it is very weak and doesn't do much. Turn the key on and open the frunk in the pitch-black darkness and that little bugger will show itself..... Jim
    Semper Fi
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Here's a great solution to your problem.
    https://www.tricledusa.com/product-p...ual-usb-plug-1
    Use in trunk or frunk.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Jun 2019
    FL
    The 2018 RTL has 1 in the funk if standing in front looking into funk its on the front right side. Mine was not connected and was under the liner, now fixed but not bright at all.
    This thread is an excellent opportunity to restate for clarity that the L and R sides of a Spyder, just like in a cage, are always in reference to the operator sitting on/in the vehicle in the operating position. For more precise identification we dip into a little aviation terminology using the clock system where dead ahead is 12 o'clock.
    Nov 2019
    SE Pennsylvania
    So I decided to sneak up on the Spyder like suggested to find that elusive frunk light .....in total darkness I opened the frunk and then turned the key to on and .........NO LIGHT to be found anywhere!!!
    From the feedback from other folks - I'm not missing much - I'll definitely bring this up when I bring her in for the first inspection.
    Maybe you can light it up like I did my 2014 RTS. https://www.spyderlovers.com/forums/...=1#post1346972
    Feb 2015
    Carson City, NV
    I think the frunk light is only on the Limited models. I do have the light.
    Bob, k7xi. 2013 RTL
    Clinton, MS
    After ripping out the liner I was able to find the light. A flashlight with dead corroded batteries puts out more light than this thing. Anybody make a replacement LED version?
    Mar 2020
    SE Wisconsin
    Well, I have a 2019 RTL
    There is a Frunk light on the front right corner as you are facing the bike.
    It seems like it is on when you turn the key on, and stays on for 30-60 secs(didn't time it) after you turn the bike off.
    Again, it did NOT seem really bright, but is better then nothing
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    The built in light on my 2018 RTL is useless. I cut a small section of the carpet and installed a couple of small LED light strips. Used the switch as the original but re-wired to come on when the frunk opens (no ignition needed) and off when closed. Works great for me.frunk light 1.jpgfrunk light 2.jpg
    2018 RT Limited "Blondie"
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Bigmo View Post
    I'd like to know which of the switch wires goes to the key switch so that I can just cut it and go to my fuse block. I've been contemplating doing the same as you did.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Trace the two wires from the light. One goes to power, the other to the switch. Cut the one going to power.
