Results 1 to 13 of 13
    Jun 2017
    Florence Arizona USA
    Angry Fans won't shut off 2014 Spyder RT 6
    I hand washed my Spyder and now my fans won't turn off. Was running great until then. (No good deed goes unpunished!) The check engine light also is on. It has been like this for a month.Any Ideas? Thanks
    Also where is the coolant temperature located? Been searching everywhere and I get everything BUT location. Thanks
    Last edited by drifterdan; 12-01-2019 at 04:58 PM. Reason: Need additional information
    SoFlo
    Unlikely washing it caused the problem, but maybe.
    Obviously best to gather the failure codes and see where it leads, but possibly the engine temp sensor failed and is telling the computer the engine is overheated. This assumes you do have coolant in the motor and catch tank.
    Nov 2012
    North Las Vegas, NV
    Are the radiators clogged ?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    SoFlo
    Excellent point. I may have incorrectly assumed with no issues prior to washing the radiators were clear. Maybe debris was washed into the fins, blocking air flow.
    Default All of the above...
    also check the plugs to the harness something has shorted causing the fans to stay on. See which way they are blowing .. into the engine compartment or outwards...
    Jun 2015
    Hampton Roads, VA
    Get code(s) first. Hold both MODE + SELECT down then press the turn switch straight in. Codes only show if the bike is running with the engine light on (or other indicators). It would take a LOT to gum up the radiator fins to the level that would cause high heat. I had years of oil and gunk on the top half of a radiator but temp was normal (I cleaned up good anyways). My guess if it happened after a wash water got on or in something like the temperature sensor. Likely whatever it is would clear up once you got the engine hot and ran for a bit. But if you see the check engine light again grab the code and post here!
    Jun 2017
    Thanks, but, I checked already. This starts from the get go, before the engine even begins to warm up. Gage still shows bottom cold line.
    Mar 2013
    Quote Originally Posted by drifterdan View Post
    This leads me to think you have a defective temperature sensor. The one that controls the fans.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    SoFlo
    As a thought towards easy and lazy, before replacing the sensor, swap the fan relay. Maybe it stuck closed.
    Sep 2018
    greensburg,pa
    I agree with PMK also-relays are known for this and its an quick it's a free check to find the problem or just unplug the sensor?
    2018 RT-L , Blue
    Aug 2019
    WI
    I have no idea if this will help or not. I have solved problems with my computers often by removing all power for 30 seconds and then repowering. If I had this issue the first thing I would do is disconnect battery, count to 30, and then reconnect battery. Cheap, easy, and worth a shot. Best of luck.
    Jun 2017
    Thanks. I tested relay and it is ok.
    Jun 2017
    Thanks. Old battery died and replaced. Have tried disconnecting battery. No luck
