Results 1 to 9 of 9
    Oct 2019
    buckhorn, Ontario, Canada
    Default Starting problems
    When I turn the key the lights go out and the solenoid clicks but no start the battery is good I have replaced the solenoid bust I’ll the same checked the ground it’s good any ideas!
    Mar 2015
    forrest above Reno, Nv
    Sure would help if the forum knew what year and model your was???????????
    Check battery and it's connections. If the battery is more than a few years old, a load test and test for alternator output is in order. Do you have a volt-ohm meter????
    2014 RTS , Circuit Yellow
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    How do you know the battery is good? Did you do a load test on it? Like Lew said if you have a Volt Ohm meter watch the voltage as you try to start it.
    Bob S
    Aug 2013
    SF Bay Area
    Sounds like loose battery connections. When you turn the key on and get lights then everything goes off when you hut the start, loose connection.
    What year? What model? How old?
    2021 F3 Ltd , Magna Red
    Default Only the click....
    Regardless of which or what you have...the "click" with no engine turn over can only come from a few places. Most commonly the battery. Especially the twins need all the the power meaning under 12 volts will not do it. So you can have lights horn turn signals etc but not enough to start her up. Battery cable connections and ground straps is another source. Lastly starter solenoid and or starter. Did you try jump starting??
    ​2012 RS sm5
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    I vote battery also.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    with Gene and the others who say check the battery connections - first ….. I highly recommend using STAR washers on the battery terminals then tighten securely ….. they won't come loose on their own - EVER ….. Mike
    Aug 2018
    Vancouver, WA
    If you're not using a battery maintainer when your Spyder is not in use, you will have battery issues, in time. Unless you have access to one of the VERY expensive battery load testers you will be unable to verify that your battery is in good health. Personally, I am using the Optimate 4 maintainer. It has some very good features. Here is a link to a YouTube video that gives an overview.https://www.youtube.com/watch?v=DGLduJXpkyE
    Sep 2017
    INDIANA, USA
    Default Starting Issue
    Just curious on what caused the NO START.
    Loose connection, battery or something else.
    Please give us an update. .....
    ENJOY YOUR LIFE WITH A SPYDER
