Results 1 to 6 of 6
    Jan 2019
    Hunter Valley NSW Australia
    Default tips when replacing front and rear shocks on RTL
    I am feeling like a kid before Christmas waiting for my Wilburs Shocks coming in the next few days for my 2017 RTL. I've been busy looking at how-to videos and posts on various forums. Given that things change so often between models (and details listed on the BRP manual I own) are there any gotchas to changing both Front and Rear shocks.
    1. remove the bolt connecting the leveling sensor to the swing arm before removing the rear shock
    2. ......
    2017 RTL , White
    Feb 2012
    Spring City,Utah
    What year is your RT?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jan 2019
    Whoops
    Edited original post to fix
    2017 RTL , White
    Jul 2016
    RI
    Askitee….I have not heard of many people going with wilburs shocks...you hear more of the elka and a few others. I look forward to hearing what you think of them, any reason you upgraded?
    Jan 2019
    Quote Originally Posted by mavrik View Post
    I think the Wilburs are hard to buy in Nth America with few distributors there.
    The BRP suspension lacks rebound control and adjust-ability on the front and I miss being able to tweak suspension settings while traveling (aside from the air adjust on my RTL). Plus the RT's get a little messier than they need in certain situations so I hope to tidy up the behavior of the bike. I researched the Fox / Elka's / M2's / specialist builders / Wilburs - the latter where the only ones where I could adjust the rear shock from a dial mounted under the seat.
    I also talked to a few here downunder, no one complained about any brand (M2/Elka/Wilburs) but those on Wilburs raved about them. Will definitely do a review on them once I have some trips under my belt
    2017 RTL , White
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    Quote Originally Posted by askitee View Post
    2. ......
    I was told you can get the rear upper bolt out from below, but in my decrepit state I had to use a second set of hands. Took all the plastic off both sides all the way back, removed the level sensor from the swing arm, and took off the bottom bolt nut. Jack until bottom bolt is just free, but leave the bolt in. One person on one side, one on the other. using a mix of wobble sockets and extensions to reach through the various holes, remove the upper bolt. Now remove the lower bolt while controlling the shock so as to not damage anything. Reverse to reassemble. The rear isn't too hard.
    For the front shocks, I found using Baja Rons instructions great. If you have small hands you can even get the bolts back in the original position with the head forward.
    https://youtu.be/EA26IlxLfb0
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
