Results 1 to 14 of 14
Thread: Bad ecu
    Mar 2018
    Indianapolis
    Default Bad ecu
    My F3 was constantly going into limp home mode. Took it into the dealership and they narrowed it down to a bad ecu. They told me that part is back ordered until January 23rd. Ugh!
    Feb 2019
    Portland, Oregon
    What year and model F3?
    Jun 2015
    Lagos, southwest Portugal
    roobus, how many miles has your F3 done?
    Mar 2018
    Indianapolis
    2015 f3s with 11k miles
    Jun 2015
    I wonder if there was a problem with some of the early ECUs.
    Sep 2013
    Houston
    If I had a dime for every time an inexperienced tech decided the ECU was the culprit....
    They VERY rarely fail. When they do, its very obvious when you connect BUDS as they either will not communicate at all or all kinds of odd things going on. The described failure (an intermittent code) does not sound like an ECU failure at all. Not impossible but not likely.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jun 2016
    indpls in
    is it at dreyer peru or flat out
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by fatboy View Post
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    ….. That was my first thought after reading the OP's issue ….. If your getting it for FREE, then it's not your problem …. if not find a competent dealer …..there is high likelihood the ECU is fine …. thsat Tech - not so much ..... good luck ….. jmho ….Mike
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Yep, it's probably going to have the same problem when they put in the new one.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Default Do wonder....🤔
    As the ECU processes all the information from all the sensors attatched to it....did they in fact check the sensors...? have any mods or work been done that could be interfearing, they seem to be the ones that fail most often. May be time for a second opinion....
    ​2012 RS sm5
    Mar 2018
    Indianapolis
    I’m just going by what they told me. Said they’ve tested everything and have narrowed it down to the ecu. Said they took one off another spyder, put it on mine and it ran fine. I’ll lose my-sh*t if I get it back and it goes into limp home mode again.
    Quote Originally Posted by roobus View Post
    This is a SAD fact of life - Dealers don't always tell the truth, and Tech's aren't always competent …. This is from Actual experience …. I'm not just repeating something I heard about …. good luck, hope it gets fixed ….. Mike
    Bossier LoUiSiAna
    any chance for second opinion from another dealer? if nothing but to decrease the chance of a return limp mode. So many sensors & triggers , a loose battery can set off a dozen itself
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
