Results 1 to 18 of 18
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Default Dream Catcher's New Installs
    Originally posted on FB …. but, I know that there are many here that never go there. Sooo …. mighty proud of the following:
    It is done and put back together (no more Spyder porn)! It only took me five days, with help from LR Smith (aka hogcowboy).... someone with more experience could do it in one. Some pics of the result - installed a power block, CB, GPS, phone holder, and Lamonster gas cap. The pig tail for the battery tender is now run in the power block, as is the GPS, and I still have four slots left for accessories. The cable for BRP connect is extended to the phone holder, so I can use BRP connect apps if I chose.
    Also, the antenna is mounted on the right side of the rear trunk using a J&M kit for a Harley that was custom built with a one foot mast (usually is two feet for that kit).
    All the best …. Ann
    NakedSpyder.jpgWiringBoxFrunk.jpgGPS Phone_RightSide.jpgCB_LeftSide.jpgGasCap.jpgFullViewCockpit.jpg
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Dec 2013
    Nice!
    And thanks for thinking of all us non face-ache readers too!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2017
    Durham,Maine
    Good job!! Boy that will keep your thumbs busy!!!
    2012 RTL , Pearl
    Feb 2019
    Portland, Oregon
    I love the job you did mounting the J&M CB and mic plug. I have one I'm going install and I'm curious as to what hardware is that holding the mic plug? Custom made? Supplied by J&M?
    Mar 2013
    Looks great!
    Note - when filling gas make sure the pump nozzle is all the way in and do not attempt to top it off once the auto shut off stops the fuel flow. Is is very easy to get back splash as the opening on Lamont's cap is so small.
    After learning this the hard way we now get very few over spills.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Bowie, Texas
    Default CB and Mic Plug Mounts
    The CB itself is mounted with the following:
    • Lamont's Top Cap, using the "mirror mount" hole.
    • The bracket is from J&M and for a Yamaha (was the only flat bracket that allowed the correct orientation); part JCB03-HBK03
    • I used a 3/4" barrel spacer to raise the CB up just high enough to use the Reverse and PTT buttons on the left control pod
    • The bolt has a TORX 40 head on it for security (was a challenge finding those).
    The mic plug in is mounted with the following:
    • Lamont's SpyderCuff that sits just inside the TopCap; gives several different mount points.
    • I purchased a single "power plate" from Lamonster garage that has a cigarette style plug for power / USB.
    • Hubby (aka hogcowboy) then cut the bottom out of the cigarette plug; as it is just a little large, I used a properly sized snap ring to keep the mic plug from being pushed through the top. We also drilled a strategically placed hole near the bottom and zip tied the mic plug into the unit (just about keeps it from being pulled out when unplugging).
    It all works well, and I think it looks pretty darn good too!
    All the best .... Ann
    Spyderpops Bumpskid
    Bowie, Texas
    Quote Originally Posted by PW2013STL View Post
    Looks great!
    Thank you for the heads up on that .... I rarely use auto shutoff because our tanks at home (with a ranch we have "real gas" delivered) don't have an auto shutoff capability. So, I just use my ears and make sure I have the nozzle inserted correctly to avoid that little splash out when removing from the cap. Do this at gas stations too, it's just become habit.
    Thanks again .... Ann
    Spyderpops Bumpskid
    Default congratulations..🍻
    We do love the DIY 'ers of which you surely qualify... nicely done
    ​2012 RS sm5
    Looks great.
    Feb 2019
    Portland, Oregon
    Thank you Cowgirl for that well detailed description. I will print it out for reference when I'm installing mine. There will be some differences as I have a F3L, but you gave me a way to start. Attached is a photo of mine on my Victory. I had one of the first Cross bikes and J&M had no hardware for them yet, so I had to wing it and it worked well for the 9 years I had that bike. Note that the mic plug is simply zip tied in place - simple, but it worked.
    Bowie, Texas
    Nicely done on the Victory ... note that this was done on a 2018 F3L. I have two Spyders, a 2016 RT Ltd (Jubiliee) and a 2018 F3 Ltd (Dream Catcher). Hoping that hogcowboy will, someday, pick up the F3 as it is getting more difficult for him to ride the Indian (MC accident in 2012 trashed his right ankle).
    Thanks for the update on yours .... Ann
    Spyderpops Bumpskid
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Spyder_Cowgirl View Post
    Ann...I shoulda looked more closely at your photos. Now I'm all the more encouraged and hoping the bracket that's on the Victory will work on my F3L. If not, I always enjoy a challenge, just like ranch folks do.
    I empathize with your hubby's injury and I like many others here had a physical problem cause them to "graduate" to three wheels.
    Active Member Charlottes Web's Avatar
    Northeast PA.
    Great job I'm going to try put a J&M CB on my F3
    Feb 2019
    Portland, Oregon
    Ann....Please show us how the antenna is mounted.
    Bowie, Texas
    I don't know why I didn't take pics of this before ... this is a J&M trunk mount CB kit for a Harley Davidson. J&M was kind enough to build the kit with a one foot mast instead of the usual two foot of the standard kit. I did add some rubber fender washers to the bottom bolt to put the antenna in a more vertical plane -- it is now very close in angle to the radio antenna on the opposite side of the trunk.
    Spyderpops Bumpskid
    Feb 2019
    Portland, Oregon
    Thanks Ann, nice job on the antenna, looks like factory. Thanks for pioneering this project.
    How was the antenna coax cable routed through and out of the trunk to the under seat area?
    Do you have the J&M part number for that antenna mount? Tried to find it on their site.
    Bowie, Texas
    I am not the pioneer on this one …. James Thorne did it long before I did (I even asked several questions of him before proceeding with my own install). The antenna coax and ground are routed out the front / bottom of the trunk (using a similar path as the radio does on the other side of the trunk). There is a pretty good gap at the front / bottom of the colored panel -- you will need to make a longer ground in order to reach the far left corner under the trunk. The part for the antenna kit is TMCBA-200 … normally comes with a two foot mast.
    All the best … Ann
    Spyderpops Bumpskid
    Feb 2019
    Portland, Oregon
    Thanks again Ann. Now I have another winter project.
