Results 1 to 14 of 14
Thread: Engine heat?
    Sep 2019
    Massachusetts
    Default Engine heat?
    As a PROSPECTIVE owner, I'm wondering about engine heat output while riding. Do certain riding conditions result in excessive discomfort? If yes, any ways to minimize it?
    Active Member bcraig's Avatar
    Apr 2019
    Grove City, OH USA
    Quote Originally Posted by greyhound View Post
    I've ridden on some 90+ degree days and the only heat I've noticed more tham ambient temps is when I would come to a stop. Hard to tell if it was coming from engine or pavement.
    It depends on what that Spyder has for an engine ….. the V-twins put out a noticeably higher amount of heat ( but could be lessened via some mods ) …. the 1330 has no heat issues that I can find ….. it is very well managed in stock form ….. I have a 2014 RT and wouldn't put chocolate bars in the glove box, but otherwise I have not noticed any heat ….. ( 45,000 + miles and as hot as 100 degree ambient temps ) ….. not an issue …. Mike
    Default Depends....
    there were design flaws but the aftermarket guys came up with cures. Most were with the early model V-twins. New models have no issues other than the normal being outside in the heat....
    Mar 2017
    I notice heat on my legs sometimes, but due to the climate I ride within, Ohio in summer SC in winter, it's mostly welcome heat.
    Sep 2019
    Massachusetts
    Thanks to all who replied. Doesn't appear to be a concern for me now. If I buy, it will be with the 1330.
    Sep 2019
    South Carolina
    Default Yes, on the heat
    Hey Greyhound I just joined the forum as I have just purchased a 2018 F3-T. I live in South Carolina and today was 98 degrees in the shade! I just came in from a ride and did notice that the engine does get pretty warm but it is not intolerable. I am coming off riding a two wheeler and I think the heat from the engine is higher with the Spyder. I am not complaining but just replying to your question with my thoughts.
    I love riding in the mountains in the fall so the extra heat will be welcome then! Don't let a little heat keep you from getting a Spyder! I love mine and have only had it a few days!
    Paul
    2018 F3-T , Matte black
    Sep 2019
    ON - Ontario
    When I rode home my new F3 last Sat it was very hot out and everytime I stopped I could feel the heat from the engine without a doubt
    May 2019
    Port St. Lucie, Florida
    I have been riding my F3T wearing shorts in 98 degree Florida heat. (Lots of humidity) Rode two wheels for 40 years, (Last was a Gold Wing), and I find the Spyder to be much cooler than anything I have ridden in the past. There is a bit of heat when you stop, but as mentioned above, it could be the heat radiating off the pavement.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Aug 2007
    Greeneville, TN
    There are a number of options to manage any heat issues the rider might have on a Spyder. As mentioned, different models/years had varying heat issues. Most riders also have varying heat tolerances as well. I've never owned a motorcycle where I didn't get some heat off the engine, especially when stopped. You have to understand that when you basically sit right over the engine/exhaust, etc., it's a bit naive to think you're never going to feel any heat. If you want climate control, drive a car....
    Jun 2015
    Lagos, southwest Portugal
    Just done 3,500 km around Spain on my new F3-S. It was hot in the south. Not once did I feel any heat come off the engine.
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    I've noticed a little heat coming off the engine when stopped and the fan kicks in on a 110 degree day. Other than that I've never noticed any heat coming off the Spyder.
    Oct 2017
    Pennsylvania
    F3's fans blow forward when stopped or moving under 6Mph - this helps a lot with heat management. I just rode from work for an hour and a half in 90+ degrees and traffic, in full face helmet and jacket, didn't notice any heat from the engine.
    Jan 2019
    SW Georgia
    I just didn’t cat delete on my F3-L. The heat on my legs at low speeds is noticeably less than with the cat.
