Results 1 to 10 of 10
    Jun 2015
    Lagos, southwest Portugal
    Default F3-s tyre pressures
    My operator's guide refers me to the inside of the right side inspection panel on the bike. I cannot find any mention of tyre (tire) pressures. Or inside the left side inspection panel. Can someone tell me what they are, please?
    Mar 2013
    For stock tires -
    18 +/- 2 #lbs for fronts
    28 +/- 2 #lbs for rear
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jun 2015
    Thanks.
    Default There you have it....
    All prior models had the information on the swing arm but not sure about the F3 from the parts decal location it looks to be on the swing arm as well...
    ​2012 RS sm5
    Aug 2019
    Stoughton, WI
    On my 2019 F3-S, the tire label is on the wall of the frunk.
    Quote Originally Posted by PW2013STL View Post
    For stock tires -
    Yep those are OEM Kenda psi's ….. and every possible combination of PSI's have been tried to increase the mileage of the rear tire …. NOTHING works to help that issue ………….. However if / when you switch to Auto tires things will be quite different …. because of the Strength of Auto tires compared to the Kenda's ( or Arachnids ) ….. folks have used this range Fronts 15-18 psi …. Rears 16-19 psi , these numbers have developed over many 100,000's of miles …. so it's no longer guess work …. ride safe - ride happy ….. Mike
    Jun 2015
    I won't be switching to car tyres.
    Jun 2015
    Thanks. I'll have a look in mine.
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    I would say the correct tire pressures are what works for you. I run the fronts harder than 18psi as it give more 'bite' from the front tires and improves turn in to corners. It also raises the ride height a few mm which helps with speed bumps and getting in and out of my drive.
    So experiment a bit and see what you think.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Apr 2019
    Florida Swamp
    Look on page 182 of the Owner's Manual. If you don't have one, it is a free download from BRP.
    That is where the tire info is listed for the 2019 F3............ not sure what year you have. You did not say. If it is some other year the tire info will still be there in the Owner's Manual, but maybe on a different page.
    2019 F3-S , Black & Silver
