My Altimax experience.
I got in from a two day trip on my 2015 RT this evening and during my after ride check up I noticed my General Altimax was showing the REPLACE TIRE tread marker to me. This tire has a few miles over 20,000 on it and will be replaced with another Altimax this week. I ride two up 95% of the time, we ride the twisty roads of SE Ohio and West Virginia often, and my traction control warning light has been on so much I think it burned out. I think 20,000 miles on a tire that works very well and was used very hard is pretty darn good. When you factor in I paid under $90 for it that makes the deal even better. I picked up another Altimax also under $90 and I will install it myself.
Good to hear...
Why change a good thing. looks like you have a good tire for your kind of ryding...change and enjoy..
2012 RS sm5
Nice to see someone not so concerned with getting a gazillion miles from a tyre, and instead more focused on grip.
Glad you had a great run from it. I don't think they are available here in Australia
To bad we couldn't put some in a box and mail them to you!!
I have always been a sport bike or sport touring bike owner and was pleased to get 5000 miles out of a rear tire. I'm pickled tink with 20K on a rear tire.
nice , how are your front tires?
2012 Spyder RT SE5 Brake pedal mod
Hey Navydad,I Ryde thru Chillicothe often, we'll have to meet for a hamburger
Originally Posted by Navydad
...and my traction control warning light has been on so much I think it burned out.
Erm, doesn't that mean the tyre has been losing grip and the traction control has kicked in to keep you safe?
Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
Rule#1: Refer to rule #2.
Federal Formosa on the front and at 20,000 they have plenty of life in them yet. I may end up changing them due to age more than wear.
Yes that's exactly what it means, but the reason the tire is losing grip is because I have a penchant for twisting the throttle rather hard. I'm a sport bike nut and I tend to ride my bikes hard. Not necessarily over the speed limit, but I love the twisty roads and corner aggressively exiting hard on the throttle. I have a sport bike in the garage, but I tend to ride the RT hard in the corners as well.
You change it yourself? Like the old fashion way with big spoons or whatever? I am tempted to try it but I don't know what to buy over at Harbor Freight
For me I get about the same distance from the fronts as the rear
I'd like to meet both you sometime. I'm from Zanesville.
The Altimax is my choice too. I ride solo all the time and get over 25,000 miles.
The Federal Formoza front tires are my tire of choice too. My last set I replaced at 47,000 miles and they weren't to the wear bar yet. But the edges were smooth.
Buckeye Chuck
I am on my 2nd General Altimax RT 43 tire on my spyder.
I ride solo.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I have three 18 inch tire irons I bought from a bike shop several years ago and I rigged up protective plastic covers for them so I don't scratch my wheels. I bought these to change the tires on my older bikes with tube type wheels. Tubeless tires are harder to change than tube type and if my buddy who owns an independent shop isn't busy I will use his tire changing goodies, but if he is booked or if it is off hours I do change my own. I have a static balance setup which does fine for my needs and I still have a nice supply of the no longer available LEAD weights.
Picked up a screw in the rear tire. Since it needs to come off anyway and has 10800 miles on it, I figured may as well replace it. The OEM Kenda is 225 / 50R15. The Altimax is 215/60R15. I’m just asking for clarification, the Altimax will have a slightly smaller diameter, but be slightly fatter? If that is the case then my speedometer will read even faster then I’m actually going? Thanks guys.
HE>I
Ozzie Ozzie Ozzie
Reason: Sorry, finger trouble, 129!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
I think the (ie.is 129mm vs 112.5mm). More Speedo correction. a good thing.
How do I delete this? Not needed.
Riding with my wife most of the time, @ about 350 lbs total. What do you guys run for psi? Looks like most run around 20 according to what I saw on other threads, but that was with varying brands of tires.
HE>I
Try 18 psi, This seems to be the sweet point. and addresses handling wet & dry and comfort …… Mike
Will do, thanks. Picking it up this morning and hopefully getting it on today so we can go see the colors this weekend.
HE>I
I got 28000miles on my Altimax before I changed it out for another Altimax
