Results 1 to 9 of 9
Thread: Eco
    Mar 2016
    colorado
    Default Eco
    I have a 2019 rt. When you hit the mod button ECO comes up on the screen. I have looked all through the book and cannot find anything. What does it do?
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Economy mode - suppose to save gas and such, I've never noticed much difference
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Feb 2019
    Portland, Oregon
    I find ECO MODE to be a royal PITA. It slows everything down and many here say it doesn't save much gas, if any. So I stay out of eco mode.
    Mar 2015
    forrest above Reno, Nv
    A useless addition to the left bar cluster. Tells you when to shift----- by taking your eyes off the road ahead of you????? Adjusts throttle response ( slows it a bit ).
    2014 RTS , Circuit Yellow
    Jul 2014
    Mint Hill, NC
    See posts #15 and #16 at this link, https://www.spyderlovers.com/forums/...er+curve+graph
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2009
    Connecticut
    On my F3 it tells you that you can shift at about + - 2,700 rpm's . Useless really.
    Sea Doo GTI-SE 90 Jet Ski!!
    Apr 2019
    Florida Swamp
    You turn it on when you are riding with a group of big, over-weight, under-powered Geezer-Glides...... so they can keep up with you.
    2019 F3-S , Black & Silver
    Aug 2007
    Boerne, TX
    Yes, worthless. Try it once and then you will know....
    I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, your journey is not complete.
    Aug 2018
    Vancouver, WA
    My local expert Spyder mechanic says, "....don't ever use Eco Mode. It only causes your oil to turn black, causes the 1330 to use oil and generally causes havoc." He said that he had a discussion with a BRP engineer about Eco Mode. The engineer said, it does absolutely nothing for fuel economy. The only reason it was put on the Spyder was to satisfy the US EPA.
