Warning axle nut cotter pin missing
I just want to FYI all, I have a 2018 F3LTD my drive belt was up against the flange. So I took a look see if I could adjust it. In so doing I discovered that the [B]cotter pin is missing. Further more the hole for it was not drilled through the shaft. I took it to the dealer and they aligned and drilled the shaft for the cotter pin. They could not believe that a flat nut with no lock washer would not have a cotter pin. You may want to check yours out I'd hate to think what could happen if that nut comes off at speed. Ride safe everyone.
Joe
As I recall, the hole is drilled not through the threads, but through the stub end of the axle.
In short, the cotter key does not prevent the nut from loosening, just prevents it from actually falling off. If you run the BRP trailer hitch, the cotter key is removed, the hit is installed, and the long bolt for the hitch safties the axle with long bolt having a cotter key.
I just checked my 2016 F3L and it has a cotter pin.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
PMK, you are correct the hole is drilled through the stub end precisely to keep the nut from coming completely off.
My thought was BRP did not believe it should require removing the cotter key to tension the belt. Regardless, I did away with the cotter key and went to a reusable safety pin. No more bending the cotter key to remove when needed, or grabbing a new one. Simply unclip as needed, and reclip after install.
But if the nut becomes loose the belt would walk off the pulley. From what I've already read no 2018's have a cotter pin anymore mine included. Could anyone show this on a repair manual if its required?
No being an ass, but I would ASSUME BRP would of addressed this already if it was a safety issue.
Update: I found this remembering I read it in this forum.
https://www.spyderlovers.com/forums/...=1#post1440860
my 2014 RT had a castellated nut, but no cotter pin.
" 2017 RT has " " " " " " "
never really missed them. Of course I don't dink around with my axle very much.
Reason: 2017 not 2917 ;)
I did send BRP a email about this with a picture of my axle and may be we can get an answer........
To me it's just common sense to have the cotter pin. Why, because there is no lock washer. Why tempt the hand of faith. I guess having worked around cars and heavy machinery it's just prudent to have it.
The starter hole is already there, my dealer drilled through and installed the cotter pin. They all commented that it should have been there.
Joe
My 2018 RTL had one side of the axle drilled, no split pin. I drilled the other side and installed the split pin when I replaced the rear tire. Overabundance of caution I reckon. Thankful they at least gave me a pilot hole on one side.
h0gr1der
2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
States Visited on Less than 4 wheels.
No cotter pin on my 2018 RTL either.
No cotter pin on my 2018 RTL. I asked dealer about this and Spyder tech confirmed that its correct for my bike. No pin used.
The pin has been removed as part of the hitch installation for years. Guess BRP decided it was no longer needed at all.
This is what they (BRP) replied with.
thank you for taking the time to contact BRP Customer Services.
As you may know, our dealers are more than just sales people; they're the best positioned people to help you with most of your requests, as they are not only technically knowledgeable, but have a lot of information on hand at the dealership. I would recommend that you to get to know them better so they can help make your riding experiences unforgettable.
Please feel free to use our dealer locator option on our website www.brp.com. I have copied the direct link to this option below for your convenience:
https://can-am.brp.com/on-road/dealer-locator.html
Please feel free to contact us anytime.
Best Regards,
Aniko Zsigmond
Customer Service Representative
BRP Support Desk Services
I'm okay with out the pin - for what ever reason its not part of the axle anymore and since my spyder has been to a dealership several times Im not losing sleep over it. I wonder if its a Prevailing torque nut? I noticed how stiff it is on the axle even when the adjuster were lose.
