Results 1 to 18 of 18
Thread: Toy hauler size
    Milton Nh
    Default Toy hauler size
    I have 2014 Ram 1500 and am wondering what size toyhauler I can haul comfortably.
    Nov 2018
    N.E. Ohio
    You need to check your owners manual to see what weight your truck is able to pull. Then decide what size toy hauler you want or need. JMO cueman
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    I definitely agree with Cueman’s comment. They do make smaller toy hauler travel trailers that might work for you.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    There are a lot of factors that go into this calculation. If you have a reputable RV dealer nearby, they can help you with your decision. The owner's manual and All of the online resources can be helpful, but you really need to know more than just towing capacity.
    First decide what type of trailer - enclosed or open ?? ……. then as said above how much weight can you safely tow ( with or without trl. brakes ) ...now for size 6 ft. wide & 10 ft. long at a minimum ….. IF ? you lay down 2 x 4's on the floor of the trailer this will eliminate accidently hitting either side .… the proven safest method of tying down is a ratchet strap place in-line over the tread attaching to the floor via some type of attachment devices …….. this is the method high end auto transporters use, nothing gets scraped or bent ….there are pics on this site … use search …..good luck ... Mike
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    +1 to Mike’s statement. Google “Erickson atv e-track tie-down kit”. I put these on an Aluma MC 210 trailer for my F3-t.
    2016 F3-T , Intense Red Pearl
    May 2019
    Hutchinson, Ks
    It will depend on what size engine is in you 2014 Ram 1500. I would imagine that even a 5.7 Hemi would have a towing capacity of about 9000 lbs. There are a lot of toy haulers available with an 11' garage that should fit the bill.
    2011 RT Limited SE5 , Pearl White
    Aug 2019
    Glendale, AZ
    I've used these guides. Look up the year/make/model/options and it should have the weight capacities.
    http://www.trailerlife.com/trailer-towing-guides/
    Nov 2018
    Claremore, Ok.
    I checked with a dealer that I trust and he said that my (only 115k miles) 2006 Dodge 1500 4 x 4 w/5.7 hemi 3.92 gears shouldn't be used with 5th wheel toy hauler. However, a bumper pull w/load levelers could be done/safer for my truck's rear axle. I'd like to put a Supercharger on my Hemi and I might be able to convince "Management" that it is absolutely necessary. Better to spend $7000.00 on the Supercharger or $70,000.00 on a new diesel truck?
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Check your drivers door for pay load sticker and start from there. May want to join a ram forum too.
    My truck is 1661 lbs and this was better than my tundra @1200 # payload towing same camper/toy hauler.
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Aug 2012
    CO
    What style cab? What engine, transmission, rear axle ratio, 2wd or 4x4? Depends on a lot of things, you can tow anywhere between 4000lbs to 8750lbs. See PDF in link.
    https://www.google.com/url?sa=t&rct=...9UrCpfOA9EQxvr
    JLohPhotos
    2008 GS , Millennium Yellow
    Nov 2013
    Oro Valley Arizona
    Forest river makes a nice 18' Toy Hauler that is easily pulled with a 1500 series truck. Work & Play by Forest River. I owned a 18' a 25' and a 36' all high quality trailers and very livable while on the road. Of course I would not recommend the 25 or 36 for anything less than a 2500 Diesel.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Aug 2012
    CO
    Also consider WHERE you're going to tow. Mostly flatlands at sea level can run heavier weights than in hills or mountains at elevation. We tow in the Rocky Mountain states and I try not to exceed 80% of the max tow rating; so I don't overwork the engine, trans or brakes.
    JLohPhotos
    Milton Nh
    It's a 5.7 hemi , 8speed , crew cab , short bed. 4x4 . I got a chance to drive a brand new 2500 , 4x4 diesel with everything at work for about 2 weeks. I tried to convince the wife we needed to upgrade but it didn't work.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Chances are you're in the 8-9k towing range then. I've got an '09 Ram. 25ft is about the limit I'd go with that, and it depends on the model. Don't max out the towing weight, you won't enjoy the ride.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Aug 2012
    CO
    Quote Originally Posted by steviep View Post
    Then according to the PDF I linked, you're anywhere between 8K and 10K depending on final drive ratio.
    JLohPhotos
    Aug 2019
    Glendale, AZ
    Those charts I linked have the year and options for just about every vehicle out there. My 05 ram 1500 pulls my FR 23' bumper pull ok - about 8k loaded. Pretty slow in the hills but brakes and steering are actually pretty good, easy/controllable. Fuel mileage though, that's another issue altogether.
    Mar 2019
    Central SC
    Towing mileage sucks with the Hemi, no doubt. He'll do a little better with the 8spd, but using tow/haul mode shuts down MDS and changes the shift point. I believe it also limits top gear.
    2014 RT-S , Orange
