Results 1 to 25 of 29
    Active Member C. Lee's Avatar
    Feb 2016
    Silver Lake, OH
    Default Speedometer inaccuracy
    Good morning all,
    When I had my 16 RTL I noticed that the speedometer was off by about 2mph at highway speed. I've just traded for a 19 RTL (see photo) and it has the same issue. Am I crazy or have you experienced this also? Is there any corrective action? Thanks for your help. Chris
    2021 Spyder RT Liminted , Marsala Red in Black
    Dec 2009
    West Oz
    Only 2% at h/way speeds - what wrong with that? They're not capable of being precise. Even tyre inflation, wear and load would give a variation.
    May 2018
    millsboro,delaware
    That seems to be the norm for many RTs,but if you change rear tire to a car tire which has a slightly larger diameter it will be accurate.
    : 2017 RTL ORBITAL BLUE
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    I'm on my 3rd spyder and they have all been 2 mph over actual speed.
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Oct 2014
    Fort Mill, SC
    What are you comparing it to?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Jun 2012
    Brandon, MS
    I’ve noticed it on radar guns on the interstate as well as my GPS and phone apps
    Quote Originally Posted by spyder01 View Post
    Like a 215/60-15 size will make it almost exact ….. Even auto & pk-up trks are slightly optimistic …. this may be a Fed. Govt. rule ……. Mike
    USA
    I did notice this on my 2018 RTL. I think it is built in for some reason. On my previous bike, a Kawasaki Nomad 1600, it was much worse. On the Spyder, it appeared to me to be 2 MPH off at 70, but unlike many other bikes it wasn't truly a linear error. It was like they put a 2 MPH error in the software.
    I installed a slightly larger diameter tire, a 205/60R15 car tire, and it corrected about half the error. I've read the 215/60R15 makes it read perfectly. I'm nit-picky, I would like my speedometer and miles to empty to be accurate, but they will never be.
    If you do put larger tires on the back, while correcting the speedometer, it will push the odometer off. In my testing, I checked both the speedometer and odometer, and while the speedometer was originally 2 MPH off at 70, the odometer was pretty close to good.
    h0gr1der
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Speedo error fix
    With a General Tire Altimax rear tire in the 215-60 -r15 size ----- the speedo is ONE mph from the GPS. Couldn't ask for any better. Every motorcycle I've ever owned was worse than that.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    I rode Yamaha Road Stars for years and they were all at least 5 MPH off. I put the General Altimax on the rear of my 2017 RTS and now the indicated speed is only 1 MPH off
    Mar 2015
    Fritch, Tx
    205/65 results in 0.5mph error at 75
    Those who say " I can't" will always be right.
    Dec 2014
    S.E. Michigan
    Every motorcycle I ever owned was off. I assumed it was to make one think they were gong fast, therefore reducing the problem of motorcyclist speeding.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Aug 2013
    Northern California
    Who Cares!
    Dec 2009
    West Oz
    Quote Originally Posted by Pirate looks at -- View Post
    Who Cares!
    Well, a dozen folks seem to. But I'm with you - same with fuel consumption and listing all the special do-dads attached to or hanging off my trike.
    Default Here's the thing..
    The only one you would need to compare yours with is the one the police are pointing at you.... and by then you will be owing the city some big bucks.... and most of them are off from yours and theirs as well....Considering this is the only adverse effect on you most law enforcement know this and do allow for some leaway....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2011
    Mitchell, Ontario, Canada
    Almost all motor vehicles are made to have some error in the speedometer. I have not looked it up recently but I believe it is -0 to +10% is allowed. It appears manufacturers aim for +2%. This allows for tire changes and other factors.
    Why is it that folks expect the Spyder speedometer to be extremely accurate? Yet their other vehicles are likely the same way and does not seem to be a problem.
    May 2016
    Ontario, Canada
    I have a 17 RTL. My speedo is off by 2-3 "KM"/hr. Doesn't effect anything. If you have a GPS that shows speed it will give the accurate reading. Running car tires at the same size as the OEM's. I'm not going to worry about it.
    Have had five 's now. They have all been 2 mph "slow" compared to standards. I use the "Your speed is X mph" signs as a guide that usually are seen at construction areas.
    My Kawasaki MC's have always been about 5 mph less than what was shown on the speedo.
    I usually do not try to compensate for the differences. We usually follow the traffic speed if there a lot of cars. If we have the road to ourselves, then I usually go posted plus 5 as a maximum. On nice scenic roads (when we have them to ourselves), sometimes will ride 10 mph LESS just to enjoy the scenery. I have not had a speeding ticket in over 20 years...and we roll through the speed traps all the time.
    Sep 2015
    Chilliwack, BC. Canada
    I just can’t understand why so many people are so concerned about the speedo error on our Spyders. As a few others have stated, all of our vehicles have a speedo error. Your cars, your trucks, your bicycle....all of them, including your GPS. The GPS depends on how many different satellites it accesses on a given reading, so....how do you know for sure how much it is out? jmho wtfdik
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Oct 2014
    Fort Mill, SC
    No one will have a perfect speedometer. Police cars have "certified " speedometers. As good as they are, just slight difference in tire pressure will throw them off.
    1998 Honda Valkyrie
    US Navy Veteran
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Freddy, I was just assuming you have no doo-dads
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    My 15' RTS is off about 4 mph. My wife's 2018 Toyota Camry XSE is off 3 mph on Cruise, but only off 2 mph when using the gas pedal. It's not because of the radar Cruise control slowing it for a car in front of it.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Sep 2012
    Stetson, Maine
    With the General, I am .5 to 1 mph off. Keep on ryding.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Dec 2009
    West Oz
    Quote Originally Posted by Raprider View Post
    I have only a few doo-dads, cruise control being one of them. The others doo-dads don't work any more, so the less said the better.
    But this thread is nearly as animated as an oil or tire thread.
    Quote Originally Posted by C. Lee View Post
    Good morning all,
    The difference is to comply with Federal and International law. I explained it all here: https://www.spyderlovers.com/forums/...l=1#post955980
