Results 1 to 20 of 20
    May 2019
    Windsor
    Default will not go into reverse
    I have a 2010 RT standard shift, over the last year I have noticed that getting it into neutral or reverse was getting harder and taking longer. But now it will not go into Reverse at all. Clutch lever and oil levels are fine and it shifts smoothly when riding, it's just the reverse. Does anyone have a suggestion as to what it could be?
    Gear Position Sensor, or maybe the clutch itself?!?
    Have you ever got any codes when it's misbehaving??
    Sep 2016
    clark county indiana
    tfatt make sure you have enough fluids in the clutch reservoir , ( when you take off the cap , is the rubber boot " on the cap " hanging down or is it folded into its self ? ( rubber boot is a diaphragm operation , it keeps the pressure in the lines as fluid is getting lower ) your cycle might be in need of internal O-rings , in the clutch housing , don`t freak out , it is an easy operation , it is getting all the Tupperware off and access to the clutch piston... IMG_20090210_162139.jpgIMG_20090210_162139.jpgIMG_20090210_172804.jpg
    Sep 2016
    this goes well with a second pair of eyes and hands ! but it really isn`t that hard to do , the rubber and brake fluid might have eaten a groove in the clutch piston housing , use very "very fine " sand paper and emery cloth to polish out , then flush with brake fluid ... ( I had a 2012 that this was the same deal , 1st gear was getting hard to hit , then reverse totally went out , the rubber O-rings just were worn out ) when you get it back together , will shift like a dream ! FOOT NOTE : read up on the "not moving the internal parts of the clutch that are the next assembly behind the piston , do not worry they will not fall out onto the floor , but the screw shaft in the center tightens and loosens the clutch plates that are behind the piston housing !
    Sep 2016
    hey tfatt ! do you happen to see fluid in the front part of the floor pan , under the front engine area ? ( use a flash light , shine under the front section , if you see some fluid ( will not be much but will cause you to panic , ) this will most likely from the clutch o-ring fail , the oil will drip out of the weep hole in the outside cover of the clutch piston housing area
    Peter does the MANUAL trans. have a Position Sensor ???? …. Mike
    Default Bu
    When my RS 2012 did this it was the clutch fluid and I had to replace the o-rings in the slave. I also had an issue with the adjustment to the reverse cable if you have to pull the lever to get to into reverse and the third issue I have seen is the shift lever itself being loose .
    Jun 2010
    Las Vegas
    Yes it does. I think his issue is with the left hand controls, the actual reverse button. If it is a 10 it probably has 9 years of crud built up.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2019
    Windsor
    I replaced the O rings on the Diagram piston, they were worn, bled the hydraulic clutch lines and I still con not get it into reverse. Its a 2010 RT-s . The clutch is a lot stiffer now and it shifts smothly into all other gears ; except reverse. Any other ideas?
    Jun 2010
    Las Vegas
    Did you check the relay?
    2010 RT- 622
    May 2019
    Windsor
    I do not know what realy you are referring to?
    Florida Swamp
    Not sure your model and year.......... on mine the RFB (Right Fuse Box), relay R1 is the reverse actuator relay. Find that in the correct service manual for your bike and run the electrical tests on it. Instructions in the shop manual. It should be fused through F7 if it is the same as later models.
    If you don't have the shop manual, you should get one.
    2019 F3-S , Black & Silver
    May 2019
    Windsor
    OK the reverse actuator has power to it but is not sucking in . Now with my limited knowledge of electricity , if it has power it should function; if not it is burnt out? I did notice that the hot wire is hot all the time I do not know if this is normal or not?
    Florida Swamp
    Quote Originally Posted by tflatt View Post
    If it has power and something is stopping the actuator or friction is making it difficult to move the actuator, it will still not be functioning. Collected crud, metal scarring, wear allowing misalignment, could all stop it from functioning as it should, even if it has power on it.
    Jul 2010
    Las Vegas, NV
    I’m thinking the switch failed, and burned up the actuator. Check the circuit, if it is hot, press the switch and measure voltage. If no change, switch is bad. Pull the fuse, measure voltage. If none, replace switch. If the actuator still won’t work, replace it. You might be able to repair those components, but IDK. Take them apart and see. If you can’t fix them, toss them, after.
    Joe Meyer
    May 2019
    Windsor
    Ok, I pulled fuse and now no power to actuator put back and power back on. I wanted to pull the switch and check it but I can not get the switch housing to come apart. I can not even find a parts breakdown in my maintenance manual.
    Nov 2018
    Waynesboro, PA
    You might try looking at Cheap cycle parts . com they have diagrams for most everything there.
    My Spyder
    2012 RTL , Brown
    IF, and I don't know how big an if it is, the 2010 wiring is basically the same as the 2014 here's what you're looking at. The hot wire, or 12 volt power, coming to the relay is hot all the time. This the norm for Can Am and Japanese systems. The relay is actuated by completing the ground circuit which is done by the ECM. The ECM completes the ground circuit in response to a CAN BUS signal from the left switch cluster. My first thought is the relay in the fuse box is bad. Pull another one from another spot and plug it in and see if you get it to work. If not, then the switch module in the handlebar has a problem. That's not an easy fix since that unit is a printed circuit board with bubble type contacts. You may have to replace the switch module. There is no feasible way, I don't think, to bypass or fix the contact for the reverse button. It's possible, but extremely unlikely, that the ECM has a problem.
    Another way to verify that the problem is either the handlebar switch cluster or the ECM is to connect a test light to a 12 volt source and ground it to the ground connection of the relay. The relay will have to be removed. If the test light lights up when you push the reverse button then you know the ECM is completing the ground circuit properly and the relay is bad. Relay contacts do go bad.
    May 2019
    Windsor
    I agree that the reverse push button needs to be removed and checked but The unit that houses it and other buttons will net come apart. I removed the screws but the haves will still not separate enough to get the push button out.
    I was just looking at the parts diagrams. Man, you've got to get it apart! A new replacement switch module is not available! The two halves of the module have to come apart completely since that's how they're assembled in the first place.
    Have you done the test light procedure I mention above?
