Results 1 to 25 of 27
    washington state
    Default towing the spyder
    Is it possible to tow my spyder?
    Nov 2015
    georgia
    Default towing
    Seems like it is possible but I would not try it, you can tow any vehicle but who knows what damage it could bring, why do you want to tow it.
    SpyderLovers Sponsor spidergreg's Avatar
    Sep 2015
    Jamestown, KY
    Default Crazy, I was wondering that!
    Quote Originally Posted by jerpinoy View Post
    This morning I was asking myself if one of the car towers that are used to tow a car behind an RV could be modified to connect to a Spyder?
    Greg and Debbie 2012 RTS
    Our Mods
    Jun 2013
    Soap Lake, WA
    I was thinking the same thing using a car dolly, a while back but was told not to do it as it would damage the bike. Not sure why.
    Sep 2012
    Junction City, KS, USA
    I think that on a dolly, you have to put the drive wheel on the dolly and the non-drive wheels on the ground. So the Spyder would have to be towed backwards. It's front end would scrape on the pavement in that configuration. All the dollies I've ever seen are configured for 2 wheels, not one. There's also the inconvenience of having to remove the windshield to tow it backwards.
    If you want to tow it, you should put it on a trailer facing forward.
    Default Yes - but
    .... It should face forward... on a wheel dolly, and the belt MUST be off......... It's a real hassle............. but doable....... Mike
    Last edited by Peter Aawen; 06-21-2022 at 09:18 PM. Reason: Removed colour for ease of reading
    Bossier LoUiSiAna
    Only with all three wheels on trailer. Flat bed tow truck. Something to do with the fluids & transmission neutral position quirks. Best to not try more than few hundred feet if at all possible.
    Bryant, Arkansas
    Towing it would probably be like water skiing on it, yes you can do it ................................ but probably only one time
    Better answer ........................ NO
    Cruzr Joe
    Default Let's see....
    I'm with them outside of the emergecy tow to get you outta the way....don't. There are nice trailers even folding ones but then thats not what your asking...
    Sep 2015
    Jamestown, KY
    Default Something like this modified
    I was thinking about modifying something like this to attach to the front A frames?
    Our Mods
    I agree with Mike regarding the belt removal, a PITA but doable. OTOH, just because one can doesn't mean one should. I personally wouldn't want mine moved any way other than on a trailer or a rollback.
    Default THE TOWING THING
    THE
    .........and Yes I know I answered above......Mike
    Default The towing thing
    Quote Originally Posted by spidergreg View Post
    ......Towing with the front wheels on a DOLLY would not be great ( and gave my opinion above ) but this would be asking for trouble .........The front " A " arms are not DESIGNED to take the stress loads this would produce....IMHO......Mike
    Last edited by Peter Aawen; 06-21-2022 at 09:15 PM. Reason: Removed colour to allow all to see/read
    Mar 2012
    NJ
    Even if dragging the drive wheel wasn't a REALLY bad idea, I doubt you'd be able to fit that tow rig under the Spyder without it dragging.
    A simple flat bed trailer is pretty easy to work out. Mine is a simple jetski trailer with nothing more than some decking installed to make a flat surface.
    Sent from my Nexus 6 using Tapatalk
    Aug 2015
    Florida
    Default Towing an RT
    I spent a good while last summer trying one-way options with U-Haul. Too wide for any of the 4 wheel trailers with ramps because the opening is narrower than the trailer bed. I still think the two dolly with the Spyder belt removed would be a good idea. However U-Haul will only rent for recognized vehicles. You could lie about what you are towing, but in case of a wreck would be in a bad way.
    May 2015
    Girard, il
    Default Car dolly towing
    Saw this setup behind a motorhome today. Slick idea (I thought)
    Mar 2012
    NJ
    Oof! Wonder what the tongue weight is on that setup?!! Looks like it's bending already!
    Sent from my Venue 8 3830 using Tapatalk
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    I always flatbed.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by Rottieluvr View Post
    I'm pretty sure that will exceed the tongue weight rating for that trailer.
    Jul 2008
    Natchez, Ms
    Default Wierd but doable
    That would definitely work altho wierd😃👍
    Mar 2012
    Spokane, WA
    Be safe get a small tip trailer such as Harbor Freight or Costco if they still have them.
    Oct 2015
    New England
    Default towing spyder by read wheel
    Has anyone towed their spyder by the rear wheel using motorcycle-rack rear wheel towing system model # CARWT500.
    If you are wondering why I want to tow my spyder I live alone and it would be nice to take my spyder in for service using my SUV or use my spyder to pick up my USV and then tow the spyder home. Thought about using a trailer to haul the spyder but not sure the spyder could tow the trailer home when leaving the SUV at the survise shop.
    Apr 2015
    Enid, OK United States
    Not sure his would work on the rear tire of a spyder I'm single an dont have room for a trailer at my house and my dealer is 60 miles away would save from renting a trailer if the F3 had to spend more than a few hours at the dealer. Anybody have any experiance with these?
    http://www.magnetatrailers.com/recei...towcaddys.html
    Mar 2019
    Roseburg Oregon
    Quote Originally Posted by johndejo View Post
    Have you tried this yet? Was also thinking about getting one.
    Mar 2019
    Roseburg Oregon
    Hello, have you come up with a way to tow your Spyder ?
