Results 1 to 16 of 16
    Milton Nh
    Default Using an iphone.
    My wife has an iphone that I would like to hook into my 2012 RT. I have the 30 pin to 7 pin rd that came with the bike. I bought the 30 pin adapter to fit the phone. I set the bike to aux and the phone to Pandora but still no speaker sound. Do I need something special to make this work.
    Apr 2015
    Tucson, AZ USA
    Have you tried listening to music on your phone vs. Pandora to see if you hear anything?
    Rob
    Milton Nh
    No I haven't mainly because I dont know how to use an iphone , I have an android. My wife set the phone up for me and she uses pandoa.
    western Colorado
    Check the volume on the phone. It can effect speaker volume on bike. I haven’t had much luck with the adapter.
    Bossier LoUiSiAna
    The screen lock timer will have effects too. The radio can control the iPod function, maybe not the pandora app, so you should be able to select station on phone screen while plugged in & adjust the radio volume on bike.
    ( Should be able , sorry not tested yet)
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member BernardD's Avatar
    Mar 2017
    Geneva, Switzerland
    Does your 30 pins adaptor you bought for your iPhone a genuine Apple one?
    I know, from personal experience, that none Apple adaptor (for me it was from 30 pins to lightning) is not compatible and did not work.
    Ride safe!
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    I have a 2014 RTS and we listen to Pandora all the time. I turn my android phone on and then plug it in to the back plug, the one in the back trunk, and then go to the buttons and the handle bar and go to AUX and then press the button to listen to Pandora. This works all the time.
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
    Mar 2017
    Geneva, Switzerland
    Quote Originally Posted by viperryder View Post
    Yes, but you are most probably using the cable that terminates with a 3/8 jack. He is trying to use the cable with Apple connector.
    Ride safe!
    Bossier LoUiSiAna
    Any Update
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    I bought a 30 pin to the newer 7 pin adaptor for my 14 RTL to use a newer Ipod touch I bought and have been unable to get anything from it, wondered if it was the adaptor, since it was aftermarket, that wasn't working, or, if BRP makes a cable for the newer Ipods. My 4th gen ipod works great and I can read the playlists and music titles but apps like Pandora or Sirius aren't supported anymore for the 4th gen.
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
    Milton Nh
    I haven't got any updates yet, and I haven't found a good adapter yet.
    Apr 2012
    SW Austin
    What is the port on the Spyder called so I can look for a cable?
    Aug 2016
    Beloit, Wi
    This works for me wireless bluetooth. 2014 RT.
    Plug this into your 30 pin male connector and then stream music from your phone via bluetooth.
    https://www.ebay.com/itm/Music-Bluet...cAAOSwiHBdLZZn
    Thank You
    Mark Light
    Live Long and Ride Hard
    Jun 2019
    jstreet
    2012 RTS SE5, bought blue tooth adaptor from LAMONSTER.. I have android...
    Plugged bluetooth rear trunk. Setting on phone to pair... Changed setting on bike. All works great.
    Blue tooth in rear trunk phone mounted in front on dash.Life is better....
    you could buy the adapter for rear trunk, either plug into speaker jack on phone. If want to get really creative. But additional speaker phone jack extension. Run cable from rear trunk to the dash. Plug into speaker jack on phone...
    I like the blue tooth. So easy....
    I switched fuse (Fuse box in Frunk) to allow continuous power to the cig lighter plug in rear trunk. Bought one of those cig lighter plugs that has USB connector... Now the blue tooth adaptor stays charged. Life is better...
    2012 RTS SE5 , Spider Web Brake pedal Orbital blue
    Apr 2012
    SW Austin
    Default bt settings
    so if i already have my BT paired with my dongle will this additional work through the dash and sound system? so many BT ...life is complicated with pairing my phone then my media....guess I could pair it to my Zumo but that wouldn't show up on my controls either would it?
    Aug 2016
    Beloit, Wi
    Power for the dogel is through the 30 pin audio cable. No need to change the fuse. Also your gps will work with this.
    Thank You
    Mark Light
