Results 1 to 6 of 6
    Feb 2019
    TEXAS
    Default factory 12 volt on ST LIMITED
    HELP!
    going on a trip, got a tire pressure/inflator for travel. Hooks up only to a 12 volt connector. Plug it in and it don't work! Works on car so not the new machine. I just replaced the fuse verifying correct choice by 2 dealers in area. The 12 volt plug STILL DOESN'T WORK! UGH! I plugged in a phone, 1st into my car and it connected for a charge. Tried it in Spyder, NOPE, no power at all. Suggestions? Ideas? Is the factory 12 volt replaceable??
    UPDATE: In the process of speaking to power sports it was suggested that yet another fuse was blown. I did find one so replaced it! The tire inflator worked but once I tried to add air to tire, It blew the fuse!! I'm guessing faulty inflator? I dunno but I'm returning it. Probably a reason in 5 years I never used the 12 volt plug on Spyder???
    Nov 2012
    Pueblo Colorado
    Spydies typically have a 3.5 amp fuse on their 12V outlets - the compressors use about 6-10 amps depending on model. I recommend using a SAE plug wire set to the battery, and change out the lower amp fuse (typically found in a battery tender harness) with a 10 amp fuse, or just use the battery clips directly to the battery terminals if needed.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Bossier LoUiSiAna
    The Quick fix found most as seen on tv in Walmart, just keep battery charged i like mine & the fact can swap to use cig plug if the battery is low. As to why your cig plug has issues, careful not to go above a 10A fuse MAX. 7A is plenty for most every 12 device & casual use
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Get a compressor with battery clips and be done with it. No bike wiring necessary. If you get a compressor with it's own battery, it will never be charged when you need it. That's Murphy's law.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Aug 2013
    SF Bay Area
    I use Co2 kit with extra cartridges. https://www.amazon.com/Slime-20240-E...omotive&sr=1-1
    2021 F3 Ltd , Magna Red
    Active Member bscofield84's Avatar
    Sep 2017
    Aitkin Minnesota
    We have an air hawk. Haven't used it with the spyders yet, but a couple times with ATV. Works great
    2014 ST SE5 LT , Black Current
