Results 1 to 14 of 14
    Jun 2019
    Bear,Delaware
    Smile Picking up 19' RTL tomorrow question help...
    Hi all,
    I got the call from dealer today that my 19 RTL will be ready tomorrow for pickup after build out. I wanted to get any suggestions about questions to ask dealer or things to go over that are sometimes missed in this process. They indicated I would see different departments, i.e. service, etc. and they will go over everything I just want to check all boxes thanks.
    2019 RT Limited , Oxford Blue
    Aug 2013
    SF Bay Area
    Make sure the Dash version is 20.8. Make sure your smartphone has BRP Connect. You'll want weither Genius Maps or Sygic for GPS. The music will be from the music app on the phone or FM radio. Never is a GPS/tracking app that is helpful. FOBO is an easy way to keep track of tire pressure.
    Congratulations.
    2021 F3 Ltd , Magna Red
    May 2017
    Mesa, Arid-Zone-A
    Make sure they have the drive belt tension lowered to the new specs. Too many dealers are still delivering Spyders with the old tension of over 200#s..... Welcome..... Jim
    Semper Fi
    Jun 2019
    Bear,Delaware
    I have put down these suggestions on the note pad for tomorrow and thanks.
    Aug 2018
    Vancouver, WA
    Ask if they have laser aligned the front end. If not, it will be worth the money to have it done correctly.
    Apr 2017
    North Central Florida
    Quote Originally Posted by IgoFar2 View Post
    Yes but......doing the alignment to the BRP supplied spec's is worthless.
    Boerne, TX
    When you get home, charge the battery to 100% and it will last longer. Dealers seldom charge batteries on new scoots. Insure correct air pressure in tires.....the same pressure in both front tires and 28-30 in the rear tire.
    May 2019
    New Mexico
    Quote Originally Posted by Mr. White View Post
    I bought a floor-model 2018 RTL - Dealer was very kind and had service put a fresh battery in before I drove it home.
    Jun 2019
    Bear,Delaware
    Thanks everyone but what's the best way to charge battery on a new bike?.
    Apr 2017
    Quote Originally Posted by SuperG View Post
    Just because it is "fresh" doesn't necessarily mean that it is fully charged.
    Still a good idea to make sure.
    And if you don't have a battery tender, NOW is a good time to get one.
    Apr 2017
    Quote Originally Posted by Sumetrap View Post
    A small fully automatic "tender" type charger.
    Available for around $30 at bike shops, auto parts stores and even WalMart.
    Many dealers install a pigtail in the Frunk for connecting to one.
    Check for that pigtail before you buy a charger.
    May 2019
    New Mexico
    A battery tender (maintainer) will work fine.
    A rule of thumb for motorcycle batteries is no more than 2 ampere charge rate - something to note if you ever have to use an automotive-type charger. More than this risks damage to the new battery.
    Jun 2019
    Bear,Delaware
    Super thanks to everyone for the advice.
    Do yourself an absolutely huge favor, RTFM, at least twice. Pay particular attention to the section on checking the oil, pages 108-110.
