Results 1 to 16 of 16
Thread: Add oil
Hybrid View
    Dec 2018
    Kettering,Oh
    Default Add oil
    I own a 2015 RTL, how do I add oil? Thanks for replies .
    May 2016
    Tombstone Az
    Apr 2019
    Yanceyville,NC
    Pages 123 and 124 in the Operators Manual.
    2015 RT Limited , Circuit Yellow
    Dec 2018
    Kettering,Oh
    Read pg 123 & 124. I am not changing or checking the oil. Do I add a small amount of oil into the dipstick? A straightforward answer would be greatly appreciated
    May 2016
    Tombstone Az
    If you are not "changing oil or checking oil". Why are you adding oil? How do you know it needs oil. You add oil in the exact same place you would put if changing oil. In the oil tank.
    Apr 2017
    North Central Florida
    Quote Originally Posted by Snackcake View Post
    Yes. The oil goes into the "dipstick hole".
    But.....you should never "add a small amount" without first properly checking the level.
    Nov 2012
    Pueblo Colorado
    If you have not rode the bike for 10 miles and then let it idle for 10 minutes before shutting it down and checking the oil, you might not need oil.
    But straight after you do, use a narrow spout funnel in the dipstick tube and add a little oil if needed.IMG_0883[1].jpg M in MAX is plenty.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Apr 2019
    Yanceyville,NC
    Yep ... DIPSTICK.
    Jul 2014
    Mint Hill, NC
    Note in the picture on pg 123 that Item 1 is the dipstick and Item 2 is the OIL FILLER TUBE (emphasis added).
    Note below the first picture on pg 124 the words "Oil level between Lower (MIN) and
    Upper (MAX) Marks:
    1. Do not add oil.
    2. Properly insert and tighten dipstick.
    3. Close the seat."
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2018
    Kettering,Oh
    Thanks Sarge
    Jun 2010
    Las Vegas
    Please be sure to check your oil per the instructions in the manual, if you don’t you will likely be overfilling it. It is not common for the 1330 motor to consume oil
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Quote Originally Posted by SpyderAnn01 View Post
    ………. So far after 9 oil changes and 45,000 mi. … I have never had to ADD oil.... this engine doesn't appear to burn any or lose any through the breather system ….. BUT, when I check it ...it is done AFTER I go for a normal ride ( 1/2 hr. or more ) ……….. that way it is ALWAYS at the proper Temp. and I don't waste a lot of time ……………….Mike
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Aug 2007
    Greeneville, TN
    Have you ever noticed that some threads are head scratchers?
    Apr 2017
    Quite a few of them actually.
    For various reasons.
    Dec 2018
    Kettering,Oh
    Thanks for all the replies. My question has been answered.
