how do you remove battery in 2009 spyder, with factory saddleHard) bags.
top left rear panel is loose and the turn light is preventing me from removing it totally. please ad vise. I did this one other time however I have forgot this step. help weather to good to miss.
Not sure...
Not Sure with the had bags and all but here are some steps on a standard RS/GS... https://www.spyderlovers.com/forums/...p?albumid=4794 Hope it will help.
Remove the tailpan. That's the panel above the rear tire. There is a bolt that holds the signal light stock on. Remove it, unplug the wires and slide it out.
