Motorbike Professor
Happy SE5 Owner!!!
Silver/Black SE5 - Trunk Liner, 1" riser, 12v, Kuryakyn ISO Grips, 5" Kewlmetal Pullback Bars, Kewlmetal Console, Zumo 450, Ipod, Kewlmetal Highway brackets with Wing pegs, Triple Play, Wizard Light LED's, Corbin front/rear saddle with Backrest, Nelson Rigg CL950 Saddlebags with CL800 Tote Bag, CalSci Medium Windshield.
Yep I have a problem too with seeing the level. I tried the small mag-lite and that works pretty good. First time I added some I overfilled it and used a syringe to get it out and down to level. I use the real heavy green anti-freeze straight when adding liquid and at least I can see that in the overflow tank. Only added about a half pint in 4000 mi8les so far. Bill
MOgang Member
I will add this, although I have never added any coolant I believe you can not (or should not) add just any coolant.. Now having said this, I maybe wrong, I know with my 2 wheeler motorcycle it has to be silicone free and I use Havaline from Auto Zone... Just a fast comment in-case it fits the spyder.. Any thoughts here NancysToy?
Just thought I would threw that out there..
Joe
Motorbike Professor
Joe
I go with the BRP recommendations. They say 50:50 ethylene glycol antifreeze & distilled water mixture, "suitable for use in aluminum engines." It will say that on the label.
-Scotty
MOgang Member
I Knew you would come back with the correct info, Thanks brother... So I'm thinking maybe the green stuff will work..
Joe
Coolant level
WE DON'T QUIT PLAYING BECAUSE WE GROW OLD; WE GROW OLD BECAUSE WE QUIT PLAYING
You want to use a 50/50 mix. Straight anti freeze does not conduct heat as well as water. 50/50 mix gets the best freeze protection and best cooling. A case of where more is not necessarily better.
I have to get some antifreeze...what is everyone using. Is the prestone 50/50 okay. I believe it is for aluminum engines or do I need to use dex-cool or prestone xtreme sport motorcycle. I guess I can just go to dealer but easier to get something at the auto store.
Thanks
It's just anti-freeze, the green stuff.....they're pretty much all aluminum compatible nowadays.
