Results 1 to 14 of 14
Thread: 2013 Spyder ST
    May 2019
    BC Canada
    Default 2013 Spyder ST
    What is the best way to effectively improve air flow on 2013 ish ST Model
    Dec 2013
    Airflow around/thru the tupperware?? Or airflow into the engine?
    The tupperware benefits from a 2014 panel upgrade, quite a few had that done to reduce the under-tupperware heat; while the airflow intothe engine can be improved by putting a few holes of about 2-2.5" dia into the air intake cover & getting an ECU upgrade. Or you could remove all the black placcy intake trunking & filter etc & fitting one of JT's CNC air filter kit intakes, but I don't know if they are still being sold/marketed?!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Oct 2015
    Lynden, WA
    Default 2013 STS Engine Airflow
    I have a 2013 STS that is being reassembled (in my garage) as we speak.
    I removed all of the Aircleaner Air Box and the Resonator. this action created a huge amount of free flow airspace.
    Replaced the Sparkplugs and Wires and performed a Canisterectomy.
    Then installed a JT Air Cleaner. It takes a bit of trimming on the plastic bits above the airfilter to get everything to fit.
    Yes, JT still has the Air Cleaner assembly for sale,
    I also drilled several 3" holes in the belly pans and had the 2014 side panels installed.
    Air flow in now incredible and heat is significantly reduced.
    Sorry no pictures until I get back in town on Tuesday.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jul 2018
    Germany
    Here you can have a look to the newer tupperware from 2014-models with extra air flow
    2014 STS SE5 , circuit yellow (metallic)
    Jun 2019
    North Carolina
    Looks Great, where did you get the 2014 tupperware? not free I'm guessing..
    Bossier LoUiSiAna
    Quote Originally Posted by wmercer View Post
    there was a good will upgrade that may still be in effect just hard to find parts or dealer that knows what to ask for. FYI mine @54k mike with the stock tupperware & only heat issue I had was a warrantied hose clamp on thermostat.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Oct 2015
    Lynden, WA
    Talk to your local CanAm dealer. Side panels for the 2013 ST are a goodwill offering from CanAm
    The side panels can be ordered and installed by the dealer at no cost to you.
    https://www.spyderlovers.com/forums/...ls#post1146306
    See post #391 kit and for part numbers.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Bossier LoUiSiAna
    Quote Originally Posted by Haze View Post
    FYI link is 404 not found
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Active Member Nobodyjj's Avatar
    Sep 2018
    Caledonia,Ontario,Canada
    Might be good will in. uSA but not in their home country of origin. Poor engineering on BRP part on ST-S, yet the RT got the kit in Canada.
    Member MusicMike's Avatar
    Dec 2019
    Moore, Oklahoma
    I just called my dealer here in Oklahoma and they told me that BRP has free 14' replacement panels only for the RT's & not ST.
    2013 ST-S , Large Brake - Show Chrome Circuit Yellow Metallic
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Quote Originally Posted by MusicMike View Post
    It's possible your dealer doesn't know about it (there was no recall or TSB if I remember correctly.) It also could be that since the ST was discontinued there is no inventory of 2014 body panels left.
    I would reach out directly to BRPcares and see if they are still doing it.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    There is no recall for it. It's more of a courtesy from Can Am if the customer comes in complaining of high heat while riding. This a "the squeaky wheel gets the grease" kind of situation here.
    Wife has a 2014 ST-L
    2014 ST Limited , Silver Platinum Satin
    Dec 2019
    Moore, Oklahoma
    Quote Originally Posted by Trbayth View Post
    I will try BRP Cares.
    Thx!
    Aug 2020
    Buffalo, NY
    Default got 14 panels for the 13
    My godson is the parts mgr at a Can-Am dealership. Tried to get gratis panels for a new to my wife 2013 ST. Godson chatted with the regional rep - no dice on panels free sycamore, at least here. Bought some (bit the bullet) and installed. Nice difference.
