Results 1 to 25 of 29
    Nov 2008
    las vegas, nv
    Default BRP stopped making parts for 2015 RS already.
    I was gonna order bearings, seal and oring for rear wheel just in case before I take rear wheel off but bearings are no longer available from BRP...
    Yes other online parts vendors still have some left but I guess this is the beginning of the end.
    6 states down 42 states to go
    Kansas
    They should have to supply those parts for 10 years minimum
    Jul 2015
    Sierra Vista, AZ
    Just looked, all parts are currently available and in stock at BRP...
    If you need us to order them for you please let us know.
    Nov 2008
    las vegas, nv
    Quote Originally Posted by SierraCycles View Post
    I need 293200094,293300124,293350065,293350067 shipped to 79756
    I usually buy from chaparral Motorsport because they offer free shipping with $39 order but those 2 bearings were blanked out and when I called them they said those were discontinued.
    Quote Originally Posted by KC61 View Post
    This true for U.S, manufacture's, however it might not apply to BRP ….. they are a Canadian co. …… but I hope you are correct ...………...Mike
    Nov 2015
    Memphis, Tenn.
    This is how RUMORS get started!! 6205-2rs & 6006-2rs are standard industry bearings and will be around for a very long time, and much better quality. O'rings and seals will be easy too!
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by aka1004 View Post
    Google the part numbers.
    https://www.partzilla.com/product/ca...eed%20In-Stock
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by jcoats1 View Post
    You are so correct. Just because one user says they can't get a part from "their" usual supplier does not make that a correct statement.
    Please check your facts before staring an unsubstantiated rumour.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Jul 2015
    Sierra Vista, AZ
    Looks like we have everything in stock and can ship out today. If I'm not mistaken one of the bearings you need qty 2?
    If you are looking for just qty 1 of the 4 parts then you should be looking at $39.76 shipped.
    If you'd like call David Levitt @ Sierra Cycles (520)459-2589 if he can help further.
    Nov 2008
    las vegas, nv
    Rumors? I have better things to do than that.
    Chaparral is an authorized can am dealer that sells a lot of oem parts and they said it was discontinued.
    As I said, those parts are still available(BRP is just not making them anymore apparently), and I did order them from procalibers along with right switch housing.
    Jul 2011
    Mitchell, Ontario, Canada
    Just because BRP changed part numbers does not make replacement parts unavailable. Since the basic rear wheel assembly on a 2019 F3 models and RT models are the same. Your implying that parts are no longer available for them too. BS. Just need to find the new number.
    Nov 2008
    las vegas, nv
    Ok. Call it whatever you want.
    Aug 2018
    Thousand Islands
    Check if maybe a new part # superspeeded the old one, I would surprised if they stopped making parts especially common ones considering i can still get parts for seadoos made in the early 90's.
    Feb 2019
    Portland, Oregon
    You live in a huge city that has several bearing supply stores. Bearings and seals are standardized. If you have one near you, you have an endless supply.
    May 2014
    Beaverton, Oregon
    Hi Mike,
    Re: This true for U.S, manufacture's,
    Do you know of any US law/legislation that requires this?
    I have heard this regarding car parts & 15 yrs, but have never found anything official that states such.
    Just because I do not know about it does not mean that such a law does not exist.
    Jerry Baumchen
    Dec 2009
    West Oz
    The bearings may be loose in their housings. If so, use Loctite 660 and 7471 primer. The rear wheel seals are not a common size, only OEM will fit in my experience.
    May 2013
    Edmonton Alberta, Canada
    Pretty sure that's a law...
    2014 RT-Ltd , Cognac
    Aug 2012
    Central Coast, CA
    He has an RS, which used a different rear wheel than the current models.
    2020 RTL SE6
    Sep 2016
    Chillicothe, Oh.
    Been riding and wrenching for over 50 years on top of doing mechanical maintenance in a manufacturing environment and I have never bought a bearing or seal from a motorcycle shop. I get those items from our local industrial supply business and I get them for less than the dealership asks for them. Oh yeah, I get name brands usually better quality than OEM parts as well. As stated above BEARINGS AND SEALS ARE STANDARDIZED no matter what the BRP part number is.
    2015 RT , Black
    Jul 2011
    Quote Originally Posted by KX5062 View Post
    That is simply not true. Why would you think that? Rear wheels from 2008 to 2019 are all interchangable. Except for the new Ryker of course.
    Feb 2018
    NorEastern, Washington
    BRP never made those parts. Bearings and seals for most anything are outsourced parts. I should also point out that most cities have business that specialize in bearings and related products. These in MNSHO, are the best place to get quality and cost savings. They can cross reference the bearing/seal numbers to get same size from a quality manufacturer and help to assure you don't end up with Asian knock offs.
    Regards,
    Don
    2017 F3T , Triple Black
    Houston
    Guys, the bearings for the wheels are very much still available from BRP. Whatever dealer gave this information is misinformed. Part numbers change all the time, you have to follow the superseded part numbers. Seems every time they change a spec or supplier.
    Interesting tidbit on the bearings, the OEM ones that come in the bike are chinese. The replacement parts we have been getting are all made in USA or Japan. High quality name brand bearings in BRP packaging. Lastly, all Spyders 2008 to current use the same 2 bearing part numbers so for parts to not be available, they would be discontinuing new spyders.....
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2012
    Central Coast, CA
    Sorry, they are different. BRP changed the design of the rear wheel. Take a look at the attached parts diagrams.
    https://www.partshark.com/oemparts/a...ve-system-rear
    2020 RTL SE6
    Jul 2011
    The OP has a 2015 with a fixed center hub. Rim design from 2015 to 2019. You are referencing a 2014 with a bolt in center hub. Rim design from 2008 to 2014. But the point is mute. The rear wheels all have the same bearings and seals and will cross fit all models and years except Ryker.
    Let's say you are correct, then BRP is wrong. The accessories catalog shows an optional chrome rim and it says will fit 2013 to 2019, RS, ST, F3, RT.
    Houston
    Yes the design of the rear wheel changed in 2015. But they are all interchangeable. A 2008 wheel or bearings and seals for it, will fit a 2019 Spyder. All of them, and vise versa.
