Results 1 to 14 of 14
Thread: Check toe in
    Mar 2018
    Ontario ,way up north
    Default Check toe in
    This is meant for CapnPete ,as i could not send pics on a PM
    2018 RTL , dark blue
    May 2018
    Salem Oregon
    Thanks for the pics.....how do you know what the toe in should be?
    Northern Kalifornia
    Isn't toe in measured at the height of the hub?
    Aug 2013
    SF Bay Area
    Laser alignment uses a laser pointer in the center axle and point to a panel 4-5’ away. They also align the front with the rear.
    2021 F3 Ltd , Magna Red
    Mar 2018
    I do realize this is not the best method ,but it is cheap and it fixed the wandering .As you can see in the pics the tape has to go under the bike so ca not measure at the axle height .
    May 2018
    Chateauguay, Qc, Canada
    stmike 1800
    Good work on those you tools you designed.
    What part of ON are you in?
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Northern Kalifornia
    Quote Originally Posted by stmike 1800 View Post
    Yep, it's a problem alright. The distance between the tires on the back side at hub height and the front side can only be done with a giant sized caliper if you don't have a laser set up. By the way, what are you going for a 1/4" toe in?
    Mar 2018
    Quote Originally Posted by Eckhard View Post
    stmike 1800
    Timmins area
    Mar 2018
    Yes 1/4 or 3/16
    May 2018
    1/4" toe in.
    Is this 1/4 "(inch) difference between the values displayed on the 2 tape measures? If yes, what is the distance between the 2 tape measures as a change in the distance would change the angular value of the toe-in generally expressed in degrees.
    What is the toe in supposed to be in Degrees?
    Eckhard
    Spyder RT Ltd, 2011
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    I used to do mine very similar but extended the side arms three feet forward and aft. This was easier to measure and at that I only had 1/8 to 1/4 toe in. When I finally had my
    alignment done by Squared Away the front wheels were aligned OK but were not aligned with the rear wheel. It is a temperary fix but if you have the opportunity to have a lazer
    alignment done by Ann and Joe at squared away then you will know its aligned right on.
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    SoFlo
    Pretty much the same setup as my QuickTricks tools I have used on vehicles for years. I did post photos of using them on the Spyder a few years ago.
    As for being aligned at axle height, that makes no difference. The dimensional toe in is carried in a vertical plane regardless of height.
    I have aligned our Spyder exactly the same way. Since my setup is more detailed, I can also check camber and castor.
    Ironically, I have corrected bikes that were laser aligned and suffered tire wear.
    As for alignment to the rear wheel, many believe heavily in that portion, when simple understanding of chassis setup, where rear alignment is dictated by the belt alignment and not centerline thrust makes it somewhat moot beyond close is good enough.
    SoFlo
    Circa 2015 when the photo was taken, but used this method in early 2014 when our Spyder was a couple hundred miles old.
    Tire wear was about nil on the oem Kendas. Have gone to auto tires for other reasons.
    Done right Toe Sticks work just fine.
    Mar 2018
    That is very likely were i got the idea .
    thanks :Mike
