Results 1 to 14 of 14
    Mar 2018
    mississippi
    Default Tupperware Question
    A few weeks ago, I saw a video of someone removing and reinstalling the Tupperware on a Spyder RT. I saw him spray a blue liquid on the rubber grommet, I am assuming to make the pin slide in better. Can anyone tell me what it would be? or Give suggestions on how to put the panels back on without messing up the grommets?
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    if you want ease of installation, use only a silicone based product so as to not deteriorate the rubber grommet.
    Personally, I like a little saliva, it is cheap, and when dry, grommets hang tight.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Nov 2015
    Chardon, OH
    Quote Originally Posted by SOlsenPHS View Post
    It’s Windex.
    Doug
    ”Freedom is not a loophole”
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    I concur.
    While the pedantic purists will no doubt say that the alcohol in Windex will dry out the grommet, Windex works well especially if you don't want to lick the grommets.
    The Power of Logic.
    Start Thinking.
    Jul 2014
    Mint Hill, NC
    +1 for Windex. Going on five years, no deterioration of grommets.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Windex?????
    No thanks, a little silicon lube yes please.
    My Gold wing had all original grommets @ 13 years old - silicon grease
    + my dealer applied it when reinstalling the tupperware.
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Jul 2014
    Mint Hill, NC
    IMO Windex is a better choice than silicone grease because the Windex dries thereby giving the grommet a nice, tight seal on the pin as opposed to silicone grease which is a semi-permanent lubrication that makes it subsequent removal of panels easier. I want the assurance that mine are all on tight. To each his own. Definitely no petroleum lubricant.
    Cognac 2014 RT-S
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    I always give a shot of windex on the grommets when replacing the panels.
    Give the lubrication when you want it, seating the pins.
    As stated when dry the windex hangs on tight keeping panels in place.
    A silicone lube may allow for premature ejection of service panels!
    2014 RT-Ltd , Cognac
    Nov 2018
    Altamonte Springs, Fl
    I keep loosing the grommet for the left side panel where you check the oil. The dealer wants $6 for one. Where else can I get cheaper grommets and any tips to keep them from falling off? I have a 2011 RT.
    Feb 2012
    Spring City,Utah
    If you are loosing a grommet you can put a plastic zip tie around it to help hold it in. I have never had a grommet come out on the oil cover. Maybe you should start using Windex
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2018
    greensburg,pa
    Quote Originally Posted by dg110270 View Post
    Exactly why I use what I stated before -keeps the rubber pliable.
    You can get them here https://www.cheapcycleparts.com/oemp...torcycle/parts
    https://www.cheapcycleparts.com/oemp...720053/grommet
    I use o-lube on my door seals car,truck,camper and tri folding bed cover rubber also.
    2018 RT-L , Blue
    Quote Originally Posted by 4 MARIE View Post
    ...and lubricant that doesn't dis-appear is going to assist an un-wanted release ..... that's when the part just leaves the Spyder in the wind and then the ground....... As far as the Rubber Grommets go - I would glue them on first ..... use a silicone type ..... I can't think of any reason you would have to remove a grommet - except for possibly painting the part ....... Mike
    May 2013
    Totally
    I super glue all my grommets to the panels, can't think of one reason to ever need to remove them...
    Nov 2018
    Thanks guys for the tips.
