Results 1 to 13 of 13
    Apr 2019
    Long Island, NY USA
    Default Innov K2 dashcam??
    Hi all,
    Wondering if anyone has installed the Innov K2 dashcam on their RT/L. Been looking at doing so and wanted to get some feedback. If so could you summarize how the install was? Where did you located the cameras and components etcs. ??
    Thanks
    Apr 2018
    Sycamore, IL
    I ordered this on Friday and getting it today. Excited to get it installed!
    2017 RT-S , Blue
    Jul 2011
    Mitchell, Ontario, Canada
    Please give us a revue after you have it installed for a few days. Thanks.
    2018 F3 LIMITED
    Apr 2019
    Long Island, NY USA
    Quote Originally Posted by Kodyw3 View Post
    Yes as mentioned, would love a review and/or how you installed it. If at all possible a video or images of install would be awesome. Yes there are plenty of them on YouTube but none that are on a Spyder. You’d be be doing a great service to be one of the first to do so and document it for us.
    I’d do it myself but my RTL is still in a create on a truck
    Thanks again
    SypderFlyer76
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    I have the older Innovv K1 system on my '15 RTL. I mounted the front camera at the center of the base of the windshield and the rear camera to the left rear license plate bolt with the supplied brackets. The recorder module I have in the left side case just mounted to the forward wall with velcro. System works great.
    2020 RT Limited , Marsala Red
    Apr 2019
    Long Island, NY USA
    Quote Originally Posted by Jetfixer View Post
    Did you need any extra length with supplied wires for the cameras? Did you drill a hole inside the left side case (assume you meant saddle bag?) ? Can you add a few pics of cam placement and how you mounted it please and thank you.
    Active Member Sarge's Avatar
    Apr 2019
    Yanceyville,NC
    Cool
    I have this system on my 2010 Kawasaki Voyager and it works great. Just PULLED THE TRIGGER on a 2015 RTL and am thinking I might get the same again and mount the monitor in the trunk and run the long rear camera to the front from the trunk. This way, I think, I can get power from the accessory plug in the trunk without having to fiddle with the battery in the frunk. AND, I only have to run the camera cable to the front. What do ya think? (Yeah ... I know ... it's Chinese.) AND it's $239. The K2 is $339.
    https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Mar 2019
    Hagerstown MD
    Any updates on your install?
    2019 F3-S SE6
    Elka Stage 2 Front and Rear w/HYD
    Can-am Dragbar
    F4 Custom 28" Windscreen
    GTR Lighting LED Headlights
    Arc Led Auxiliary lights
    Signature Light
    BajaRon Swaybar
    Akrapovic Sinister Silencer
    FOBO 2 Trike TPMS
    Motorcycle Dave Gel inserts Rider and Passenger
    Foam Grips
    2019 F3-S , Monolith Satin Black
    Mar 2019
    Hagerstown MD
    Quote Originally Posted by SpyderFlyer76 View Post
    Hi all,
    Thanks
    Any thought on the Blueskysea Dv688? Did you pick the K2 over the 688, if so why? Im looking in to dashcams and these seem to be the most sought after cams.
    2019 F3-S SE6
    Can-am Dragbar
    Signature Light
    BajaRon Swaybar
    FOBO 2 Trike TPMS
    Foam Grips
    Apr 2019
    Long Island, NY USA
    Still have not purchased my setup yet. After much research the K2 really seemed to been the favorite of a lot of 2 wheel riders. The 688 didn’t really return much reviews during my research.
    Feb 2016
    Sorry to take so long to respond. I had enough cable to install as you see in my photos. Did drill a hole in the left sidecase, popped in a rubber grommet to prevent chafing. I even installed to "panic button" on the left handlebar. The button marks the current file to not be overwritten.
    Apr 2019
    Long Island, NY USA
    That’s awesome. What are your thoughts on the system so far? I’m assuming you have it wired to power on with the key? How much footage can you realistically record before it overwrites? Thanks for the pics BIG help!!
    Feb 2016
    I had a problem with power using a "key on" power source. I solved that by only powering it when the engine is running. I think it was sensitive to the voltage drop when the starter engaged. I used the "unused" F8 power position in the RFB using an "Add-A-Circuit". Now that circuit is only powered through the load shed relay. Works great.
