Results 1 to 14 of 14
Thread: Horn
    Jul 2011
    Vermont
    Default Horn
    I am thinking of replacing my stock horn for something that people can actually hear. Any suggestions. I have a 2014 RT Limited
    Nov 2018
    Waynesboro, PA
    2012 RTL , Brown
    Quote Originally Posted by Phyllis View Post
    Hi Phyl …. remember even Fire Trucks get hit and there is nothing on the road that has more lights , air horns and sirens than them …… My first line of defense has always attention and then avoidance …… It certainly won't hurt, as long as you DON"T relie on to save your B*** ……….See you soon ….. Mike
    Idaho
    Whatever loud horn you get don't expect a dramatic increase in perceived loudness. A few years ago I had my 2013 RT with stock horn beside my ATV with a Stebel Nautilus horn. From across the street there was very little difference in loudness between the two horns. Nevertheless, I had two trumpet air horns on my 2013 RT and installed a like set on my 2014 RTS. You can see them the ones I had on my 2013 in the pic below. All three horns, the two trumpets and the stock, work together. They are not a whole lot louder than the stock horn by itself.
    2014 Copper RTS
    Feb 2019
    Portland, Oregon
    My F3L has a single car type trumpet horn that's pretty loud. I plan to add a second trumpet for that more piercing dual tone. Had that on my previous bike and it was an attention getter. Drivers would look for a car, thinking they heard one. Tee Hee.
    Default choices, choices
    I got the Rolo Bad Boy and was never impressed. Different sound but not much volume. I later put the stock one back on and added the loudest single trumpet horn at the auto parts and together they do a good job...
    20180603_111237.jpg they come in high and low I added the low as the stock one is high.
    ​2012 RS sm5
    Nov 2013
    Central Texas
    Got mine on Amazon considerably cheaper & got it in 2 days.
    https://smile.amazon.com/Wolo-619-Bi...s%2C133&sr=8-3
    Mar 2015
    forrest above Reno, Nv
    Good Morning Phillis,
    And Happy Easter-----
    Which ever horn you get use a relay to switch it. I've had both a wolo and a Striebel. At the same time on two motorcycles ( both with relays and good batteries ) The Striebel is louder . Verified by my wife. Really.
    Lew L
    2014 RTS , Circuit Yellow
    Member SpyderHubby's Avatar
    Feb 2015
    Northern Virginia
    I have the Fiamm Freeway Blaster (high and low tone) horn on my bike. The two horns work together to sound very similar to the horn of an 18 wheeler. 132 db of attention-getting sound. You can purchase the horns from Aerostitch for $18.00 each. A relay is available for a couple of bucks. Highly recommended.
    Hers - 2014 Can-Am RTL Platinum Satin and matching RT-622 Trailer
    His - 2014 BMW F800GS - Kalamata Matte
    Member Rickster48's Avatar
    Aug 2018
    Northeast TN
    These Fiamm am80S horns were on my Yamaha FJR. They do get attention when needed. Bracket and relay are included.
    https://www.amazon.com/s?k=Fiamm+Ele...ref=nb_sb_noss
    Have a set for my RT which will get installed this week along with a BajaRon sway bar.
    Jul 2011
    Vermont
    Default Thanks everyone.
    Thanks for the suggestions. Read a few reviews. Difficult to make a decision due to ratings. This summer I am going to ask everyone if I can hear their horn. So, if you see me, blow your horn.
    Feb 2019
    Portland, Oregon
    I have a pair of 115 db PIAA horns I'll install with a sway bar. I had 110 db car horns on my previous bike, a Victory Cross Roads and those were loud.
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    Plus one for the Stebel Nautilus.
    One farkel that really did get me more space was a set of Hyperlites (flashing brake light setup). I bent a piece of sheet metal for a bracket to mount them adjacent to my license plate. When I stop, most people leave a full car length - or more - behind me. If I release the brake, no more Hyperlites, and the cars edge up to by rear wheel. Not very scientific but it's pretty consistent.
    Feb 2019
    Portland, Oregon
    I had Hyper-Lites on my last bike - they were wired as running and brake lights that flashed 5 times when the brakes were applied and then on steady.
    I installed this little gem in the 3rd brake light in the top case of my F3L. I used Posi-Locks, not those red connectors....
    https://www.banggood.com/20W-LED-Bra...r_warehouse=CN
    Its very tiny, so it fits in the space very nicely. Apply the brakes and it flashes 3X fast, 3X slow, then on steady.
