Results 1 to 19 of 19
    Feb 2019
    Vancouver, WA
    Default Stability at Freeway Speed?
    How stable is a F3 at highway speed?
    I recently had training on one; but, never had the chance to exceed 30 mph.
    So I'm curious how stable or squirrelly it might be at 0-75 mph?
    Sep 2013
    Houston
    Properly aligned and with high quality tires, they are VERY stable at highway speeds and above. One finger easy....
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member osj3's Avatar
    Aug 2018
    Greensboro NC
    rock solid. Granted I do have Elka Shocks, belt tensioner and a sway bar which i feel improved my ride at both low and high speeds
    2018 F3 , Black on Black
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    I cruise at 70+ on my 2017 RTS with ease. Also pull a Rollahome camper at 70. Spyder is a very stable and capable machine for this 75 year old with 60+ years riding under my belt
    Aug 2013
    Northern California
    Would suggest that you install the Baja Ron Swaybar, and have the unit laser aligned, for complete peace of mind, BUT, that sucker will still be very solid. With the above mentioned improvements you will have a very easy time on the highway!
    Aug 2007
    Greeneville, TN
    Rock solid at speeds well above the legal limit. Don't ask me how I know...
    Nov 2018
    Virginia
    I have found it to be very stable but you have to keep a relaxed grip on the handlebars. I have found that just like a dirt bike it is more stable if you stay loose. If you tighten your grip you will induce instability. In small planes it is a PIO (pilot induced ocillation).
    2018 Can Am Spyder F3L, 1995 BMW R1100R, 1988 Suzuki GS250, 2019 Ryker 600 (Wife's)
    With more than a couple of 600 mile days at highway speeds: they'll be steadier than you are!
    Just keep a light grip on the bars, and you've got nothing to worry about.
    Active Member bushrat's Avatar
    Apr 2017
    Peterborough, ON, Canada
    Our 2017 F3L is pretty much a 'stock' vehicle, with only slight modifications to seat - no added sway bar, belt tensioner, etc. We ride two-up about 80% of the time. Mostly, we prefer back country, 'secondary' highway cruising averaging probably 50 mph. However, we have ridden on occasion on Interstate highways as high as 75 mph. I have been solo as high as 80-85 mph for some modest length periods, moving in traffic, passing semis, etc. Never have sensed any instability or lack of solid road feel. Don't really enjoy riding this way much; don't particularly like the 'vulnerability'. Country sight-seeing is much more fun. But I have never doubted the reliability of the Spyder or its ability to handle extra speed on decent pavement. Would never have twisted the throttle in the first place had I felt any qualms.
    [SIGPIC]
    2017 F3 Ltd. Intense Red Pearl/Metallic Black topside
    2017 F3Limited , lowered brake pedal Intense Red Pearl w. Metallic Black topside
    Apr 2017
    [SIGPIC]
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Very stable. I never have seen the need for laser alignment for both of mine, but the sway bar does help with buffeting and changing road conditions at higher speeds. But just like a car there can be unexpected events occur (deer, chuckholes, and crazy drivers come to mind). Just remember you are not afforded the extra protection that a car gives and to allow for these events by providing extra following distance for cars in front and awareness of those around you and how they are driving. I will adjust my speed to try to avoid those circumstances. Getting there safe is much more important than getting there fast...or not at all.
    Seat time and a few hundred miles....you will like it a lot.
    Box stock off the showroom floor they are very steady and the one needing the adjustment is the driver if new to this kind of vehicle. The modifications come after as you get better and feel the need for speed... Now when you get yours make sure the dealer aligns it properly and if they do not have the laser system take it to someone that does.
    ​2012 RS sm5
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    I run my 2015 F3 at traffic speeds, usually between eighty and ninety and it's rock solid with either one or two people aboard. No alignment, no away bar, the only issue I have is belt vibration at about fifty five.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Once I replaced the crappy Kendas on the front with Kuhmos, my Spyder became very settled on all roads. Complete change in temperament and handling.
    Dec 2018
    Elanora, Qld, Australia
    Well said jcthorne. Start with correct wheel alignment. All else flows from there. If wheel alignment isn't correct riders will never be satisfied with the stability.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    May 2017
    Mesa, Arid-Zone-A
    Properly set up and with capable tires there are no stability issues. Today I passed 2 trucks on a 2 lane, less the perfect road. I thought there was only one truck at first until I began my pass. I had to kick it up due to limited safe distance. I passed them both while hitting 90.....all while pulling my RT622 trailer. At no time did I feel any instability. Mine is an RTL but I think the F3 and RT are equally capable..... Jim
    Semper Fi
    Active Member Jeffmal's Avatar
    Jan 2018
    Plantation,fl
    Did the Elka shocks help with high speed jitters in the wind?
    Which Elkas did you go with?
    Aug 2013
    Northern California
    Quote Originally Posted by Jeffmal View Post
    Interesting the alignment and Swaybar should have corrected that!
