Oil change kit - what does it cost you?
Hello to all, I am just curious ,here in Canada it cost me $110 Canadian to do a oil change with the can am kit. What does it cost you in the lower 48 to do a oil change with what oil and filter. Thanks.
2015 RT Limited
5 Quarts of Amsoil, filter and O-rings from Bajaron about $80.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Depends...
Are we talking only the oil, filter/s O rings etc. Or are we talking supplies and labor..? What model, engine and transmission..?
For me...2012 RS sm5 using BRP blend kit bought online and doing it myself = $65.00 the se5 is like $80.00
Not familiar with the 1330 triple costs..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
$79.95 for the 1330 se6 kit from my dealer.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
5 quarts of castrol full syn. on amazon for 33 bucks....A kn filter from there as well 7 bucks. Total 40 bucks.Use the rings 3 times. I change at 6000 miles 2014ST. The 10 40 or the 5 40 are both 37 bucks per 6 pack shipped on amazon today. Most times its aprox. 50 bucks a 6 pack. This is a fine motorcycle oil......Much better than the BRP Blend.
Rotella T6 full synthetic 5 qt=28.70
filters (2) and washers and o rings from Baja Ron=25.95
2012 RTL with electric shift. O rings and washers do not need to be changed every time
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Mike do u use the T6 extreme weather or the T6 multi vehicle one
2015 RT Limited
I'm also in Canada and it costs me about $75 CAD to do a change.
I took the seals from a BRP change kit to a seal shop and had them make me some kits up with higher quality seals than what is supplied. ($11 a kit)
Order my filters online from Fortnine ($9) and get my oil from Amsoil. ($55)
My container lists this info … T6 - 5W/40 - heavy duty Diesel -Synthetic Extreme Temperature..... I'm pretty sure my first container said the same thing …… Mike
Ok thanks Mike just the words heavy duty diesel scares me a bit in a gas engine. But it sounds like most are using it so I will give it a try. Thanks
2015 RT Limited
I paid $ 169.10 at dealership that includes:
1 Gasket ring,
3 O rings,
1 Gasket,
1 filter oil,
5 quarts of Valvoline 4T Stroke Full Synthetic Oil( Superior Wet Clutch Protection) SAE 10W -40, ( I supply the oil)
Also, the above price includes Storage prep and summer ready, VSI, oil and filter change.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Do you balance the bike on one leg and one hand Mike? It might help a little bit. It still leaves a leg and a hand to do the work.
I've always done them myself, and I've paid $85 and I've paid $40....it all depends on what oil you buy. I haven't seen any advantage to buying the more expensive oils. It's Rotella T6 for me next time. I DO think it helps to spend a little more on a quality filter though.
