Results 1 to 10 of 10
    May 2012
    pa
    Default FM radio interference with LED fog lights
    I recently installed a Boss FM radio on my 2015 F3s equipped with Lamonster LED fog lights. When I turn the fog lights on, the radio sound disappears completely, yet I can use my MP3 player thru the same FM amplifier without a problem. The Lamonster did send a pair of anti-flickering filters that made no difference. I now have to decide when riding, do I want fog lights or FM radio, not both simultaneously. I would appreciate any thoughts.
    Vermont
    I had a the same thing happen on my 2014RTS-SE6, installed a resister.
    I don't have any problems with my radio.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by palover View Post
    My neighbor installed decorative outside flood lights on their home. when turned on the garage door opener won't work. They need to have the type of flood light bulbs changed. Hard to believe a light bulb can cause that much interference--But it Did :-(
    May 2012
    pa
    Great - how about more detail ie where was the resistor installed (LED line -speaker - amplifier line), type of resistor and where purchased
    I have been struggling with this problem from day one and very frustrated.
    May 2012
    pa
    I too did not have a problem installing LED headlights and fog lights on my 2014 RT. It is the Boss radio installed on my 2015 F3s that is giving me headaches. Just cannot use fog lights and radio simultaneously.
    I've posted on a different Thread about this issue ….. Some LED headlight units are not properly shielded AS THEY COME FROM THE MANUFACTURER. a set that I bought for my Toyt. Tacoma interfered with my radio … ( and still do ) … I bought another set ( 4 lights ) from a different company - these do NOT interfere with my radio ………… I also have LED headlites from Reggie on my RT and they DO NOT interfere with my radio...…. If you bought a set of LED's and they interfere with your reception get in touch with the Seller and get your money back ...……….. Mike ...……….PS on Ex-rockets similar thread another member posted about a Capacitor that should solve the interference issue
    Sep 2009
    La Valle, WI
    I just installed lamonster led headlights and auxiliary lights on my F3L. Headlights are fine. auxiliary lights kill my FM radio signal. Have to get a hold of lamont.
    2018 F3 Limited , Oxford Blue
    Greenville Tx
    I had this problem and just called Jacob at Lamonster Garage. He semt me out some RF filters to install in line and they worked fine after that.
    2017 F3 Limited
    Mar 2015
    forrest above Reno, Nv
    Bought my headlights and fogs from brand T and there are NO problems.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2013
    Marion, Arkansas
    I have another thread about the same problem that I started in the general discussions.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
