Results 1 to 25 of 33
    Mar 2013
    Marion, Arkansas
    Default Interference from Fog Lights
    I have a 2017 F3Limited and just recently had a bunch of LED's installed on my bike. The list includes, LED headlights, LED fog lights with halo ring, both A-arms LED's, Slyclops LED under front truck lid, full view turn signal LED's, LED's on rear which a run/brake /turn and fender LED's.
    Now here is the problem. With the fog lights off my radio functions normally but as soon as I turn the fog lights on I can not hear the radio. Anybody have this same problem and know of a cure?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Sep 2018
    DFW, TX
    Interesting. I just recently added the LED fog lights with the ring lights and LED headlight. My radio reception in now crappy like there's a lot of interference. Didn't notice if it was worse when I turned the fog lights on. Hmm, have to look at that when I get home in a couple of weeks.
    I posted about this problem last year ….. Put LED's in my Toyt trk and lost most of my radio reception …… Then discovered the LED's I had purchased fro ******* caused the same problem on my 2014 RT ….. I told Reggie about it and He gave me a set ( His newest version ) to re-place them ….. Those gave no problems …… I recently bought some very high power four-sided LED's ( 9005 & 9006 ) on E-bay..... No interference from those …. However when I first turned them on - NOTHING … no lights at all …. I finally turned the plugs around which reversed the polarity - BINGO - they are extremely bright and still no interference …. the Seller refunded me 50% for solving the problem ...………. So be warned some LED's will cause radio interference …… good luck …. Mike
    LEDs are notorious for putting out RF noise. Cheap Chinese knock-offs are most likely the worst offenders. IMO, the Spyder wiring does a great job of carrying RF noise all around the system, so anything that emits RF noise is going to be problematic. The radio on my 14 RT is clear as a bell if I shut the motor off using the kill switch. Turn motor back on and the radio is mushy.
    Sep 2009
    La Valle, WI
    I just bought lamonsters led headlights and foglamps. Haven't installed yet. Are they going to interfere with my radio reception.
    2018 F3 Limited , Oxford Blue
    Feb 2019
    Portland, Oregon
    Sometimes, wrapping the black boxes (can't think of their name) in aluminum foil works.
    Apr 2017
    North Central Florida
    Contact the company that sold you the LEDs to see if they can help.
    One (or more) of the replacement interior LEDs I put in my RV interfere with the TV sometimes when watching "off the air" stations.
    Nov 2018
    Claremore, Ok.
    When attaching the ballast, or whatever it's called, don't allow it to contact ANY metal!!! That's what's causing the interference. I bought LED headlight bulbs and turn signal bulbs (resulting in Hyper Flashing)for my Dodge PU and it really messed ( up the CANBUS. Try using a OBD2 reader to reset the CANBUS to accept the LEDs. Also, the wires into the LEDs were backwards, Brights on low beam and Low Beam on Bright switch. Just pull the pins and swap them. Are we having fun yet?
    Quote Originally Posted by Revalden View Post
    " Just pull the pins and SWAP them " .. … the Pins are attached to wires molded into the housing , swapping them won't change the polarity in the plug ……. Also I've had the Ballast apart , the actual part is buried in Non-conductive material annnnnnnnnnnnd the entire housing is Plastic which is non-conductive ……. Mike
    Apr 2017
    Maybe he is working with a different model "kit" than you are.
    Just maybe.
    Just maybe.
    ……….. I've changed Dozens of headlight/lamps ...halogen and led …. the attachment plugs are of a Standard type …… please show a pic of one that is different …. I've never encountered one ………… bad info in - bad info out …………..Mike
    Apr 2012
    Florida
    I have Lamonts LED headlight, and fog lights. They will interfere with the radio. Mine are doing that. Tom
    2020 Petrol Blue Metallic RTL
    The LEDs I used are from *******. There is a connector between the ballast and the plug that goes into the bulb that is reversible.
    WHAT? Reggy's company name is censored???
    Sep 2018
    greensburg,pa
    No noise on mine!
    2018 RT-L , Blue
    May 2012
    pa
    I purchased a Boss amplifier with FM. When I turn on the (Lamonster) LED fog lights the FM disappears yet I can play my MP3 without a problem. Can anybody offer a solution?
    Vermont
    Quote Originally Posted by palover View Post
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Mar 2013
    Marion, Arkansas
    Use a resister.
    Deanna
    What value resister and wattage and where did you install it? Share your information.
    May 2012
    pa
    Would be good info to have and may solve my problem
    May 2012
    pa
    We share the same problem, I cannot listen to my radio with Lamonts LED fog lights. Did you ever find a cure??
    Jun 2018
    Melissa, TX
    Quote Originally Posted by Ex-Rocket View Post
    Actually, you're looking for a capacitor
    RADIO NOISE CAPACITOR CONDENSER UNIVERSAL .5MFD FOR RADIO NOISE INTERFERENCE
    May 2012
    pa
    If F3s, YES!!
    May 2012
    pa
    Where do I purchase this .5MFD capacitor and where is it connected?
    What I referred to was ….the SHAPE of the plug …………...Annnnnnnnd reversing the one you have will change the POLARITY ….. On an LED - this is likely to Prevent it from … LIGHTING at all …… good luck …. Mike
    May 2012
    pa
    Installed on the F3s - YES!!
