Results 1 to 13 of 13
    Jul 2008
    Wilmington, NC
    Default No power to right fender
    Any one have this problem?
    Replacing wires on fender now there is no power?
    Is there a fuse?
    Default Curious...🤔
    There are no individual fuses to each fender....but if you are replacing the wires I would start by checking all the connections and seeing if you have power at the source of your new connection. Did you check power with a meter or just the light connection..? if you are using LED bulb remember they are sensitive to the correct +/- connections...
    Jul 2008
    Wilmington, NC
    I had power till i hooked up the LED....... can I reset it or how do i fix it?
    Quote Originally Posted by nyfdtsdemt View Post
    Are you sure the LED is a working unit ??? …. Have you tried turning it around and re-inserting it …… Mike
    Vermont
    Is any of the LED wires rubbing on anything under the fender?
    What year is your spyder?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jul 2008
    Wilmington, NC
    i took them off now there is no power to the light with none of them connected
    Jul 2008
    Wilmington, NC
    2012 rt
    Jul 2008
    Wilmington, NC
    Brand new and yes they all work it the top side and back fender units
    Jul 2008
    Wilmington, NC
    Figured it out you will never guess what it is?
    A broken wire ????? …………… Mike
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Maybe forgot to plug the harness back in under the A arm???
    Jul 2008
    Wilmington, NC
    Yeah but in the strangest spot the female connector on the wire harness 35 bucks later FML!
    Bossier LoUiSiAna
