How do I adjust clutch?
The dealer said I would just need 17 mm and Allen wrenches. But once I insert alen wrench am I still holding the nut
Need more info....
from what I can see you have an older rs/gs/rss but is it the semi-automatic or the manual. Then why are you looking to adjust the clutch, what is it doing..?? If it is slipping it can be for a variety of reasons...Let us know so we can help....
Ozzie Ozzie Ozzie
What is it doing that makes you think it needs an "adjustment" ?
Hydraulic clutches generally do not need to be "adjusted".
But worn master or slave pistons can cause the clutch to drag........and adjusting is not the way to fix that.
