Results 1 to 22 of 22
Thread: Engine miss
    Feb 2019
    LA
    Default Engine miss
    Is it normal for a 2012 RT to miss in neutral with the engine reved?
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    wondering if you are hearing the unspent gas getting back fire through the exhaust ? if you drive around , listen to the exhaust , kind of lean back and hear the noise see if you hear popping sounds , I hear this at different times with both the r-t`s that I have ridden ...
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by drkennedy61 View Post
    Probably not. But not enough information to give you a good answer.
    How many miles on the Spyder?
    Have the vacuum lines been checked/replaced? If yes. How long ago?
    Have the ignition wires and or spark plugs been replaced? If yes. How long ago?
    This might help us to give a better answer.
    Feb 2019
    LA
    There are only 2500 miles. I dont think the wires and plugs have been changed. I was just wondering if age could haverotted the wires causing a miss. I also notice a slowing down all of a sudden, like the brakes are applied. I was thinking a plug wire was shorted to ground. I appreciate any info. It seems like a hard job. I checked the vaccumn lines and they look new
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    Vacuum lines can look new and still have micro cracks. My RS was running rough, replaced vacuum lines and used Baja Rons plug wires and plugs and it is running better than ever. Dealer did the work and cost was $180, plus the parts.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Feb 2019
    LA
    I did not hear any popping sound while cruising. It feels like the brakes are being applied. Like a wire may be shorting to ground.
    Aug 2007
    Greeneville, TN
    2,500 miles on a 2012. That is a lot of sitting. Could be a good number of things. I would start by checking tire pressures. 18-20 psi in the fronts, 26-28 in the rear. Then fill up with premium, non-ethanol gasoline if possible, and adding 1/2 can of Sea Foam to 2 consecutive, full tanks of fuel. I would check the vacuum lines on the left hand side of the throttle body as well. Even if they look good I'd replace them if you go to the trouble of removing the air box to check them.
    It could actually be your brake pads hanging up. Easy to check. When you feel like you are slowing down, try to safely pull over without using your brakes. Then, using the back of your hand, get close to each rotor. If there is little or no wind you should be able to feel the heat from the rotor. If you have not used your brakes, the rotors should be just a bit warm at most. And they should all be about equal temperature.
    You'll just need to go through a series of checks like this as a process of elimination to find your issue(s).
    Feb 2019
    LA
    Thank you very much for the information. I will try the suggestions when the weather gets better.
    Feb 2019
    LA
    I am now getting the check engine light comming on. I checked for a code and got p1171. Any more suggestions?
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    A quick search shows the P1171 - System too lean bank 1. Front cyclinder. Could be caused by cracked vac hoses.
    Check this thread: https://www.spyderlovers.com/forums/...ror-Code-P1171
    Joe
    2023 F3
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by tibadoe View Post
    Bad vacuum hoses will give you fits. Change them out even if they look good. At least this will eliminate that possible issue. And your Spyder may run really great with just this little fix.
    Feb 2019
    LA
    Thanks, are there hidden vaccumn lines under the air box? I am going to get some seafoam and try that.
    Oct 2015
    Lynden, WA
    Thumbs up Vacuum hose replacement
    Check this thread for pictures and direction to replace the vacuum hoses.
    https://www.spyderlovers.com/forums/...t=vacuum+lines
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Aug 2007
    Greeneville, TN
    Yes, they are located under the air box on the left side of the Throttle Body.
    Feb 2019
    LA
    Thanks, I checked these and they have been changed to the silicone kind.
    Aug 2007
    Greeneville, TN
    Diagnosing issues over the Internet is challenging. The next most likely source of your miss would be spark plugs & wires. But these would not account for your lean code. So if your vacuum hoses are good and properly connected. I do not have a good explanation for that code. Though bank 1 does tend to run lean normally. Cylinder 2 (rear) seems to get more fuel in the mix. Maybe because it is the rear cylinder which may tend to run hotter. Though with a liquid cooled engine. You wouldn't think so.
    Feb 2019
    LA
    I appreciate all the help. I may end up bringing it to the dealer.
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    rev limiter, when excellerator exceeds the safe RPM of the motor
    Feb 2019
    LA
    I brought it to the dealer, all they did was cleared the code and charged me money. The cel came on my first trip out. I Will look further into the problem. I sprayed some carb cleaner around the throttle body and the engine seems to lower rpm. It seems worse around the back cylinder
    Feb 2019
    LA
    problem solved! I remove the airbox and there was a vacuum port on the right front cylinder. This port is used tp activate a clutch valve on other models. It should be plugged on an se5. Mine was wide open sucking vaccumn. I hope this helps others that get a p1171code. I changed my plugs and wires while i had the access. Got them from Baja Ron, nice guy
    Feb 2012
    Spring City,Utah
    It is always nice when the solution to a problem has been posted. Thank you for letting us know. I too have an SE5 so now I know where to go.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2007
    Greeneville, TN
    It is always rewarding when the solution is posted. Disappointing when a number of posts are logged in an attempt to help and the OP never comes back.
    Glad you got it worked out. Simple is always good!
    Thanks!
