Results 1 to 13 of 13
    Active Member always young's Avatar
    Oct 2015
    Melbourne, Fl
    Default 2016 F3 Ltd rear rim width
    Couldn't find this info off had with a search. Can someone tell me the width of the rim on the rear wheel. Yes, looking for new tire and wanted to make a comparison to a car rim width. Thanks much.
    Life is attitude, be positive!
    Jul 2011
    Mitchell, Ontario, Canada
    7 inch
    2018 F3 LIMITED
    Oct 2015
    Melbourne, Fl
    Thanks. That was quick.
    Quote Originally Posted by always young View Post
    Just a suggestion the TIRE Rack has very useful info on rim width vs, tire size ……… And to make things simple just get a Michelin " T & H "defender in 215/60 -15 and save yourself a lot of time.... This tire thing has been debated & decided for a looooooooooooooooooooooooooooong time. …..jmho …. Mike …..Correction the " T & H " tire size should be " 205/60-15 " ...... sorry for the typo ...... Mike
    Sep 2013
    Houston
    No Mike, it may have been debated but its not decided that is the recommended choice at all. Especially for an F3, it has pretty limited traction. We find the recommended Yoko S-Drive a FAR better tire. And the size you quote is significantly taller than OEM and DOES cause trouble on some bikes at the rear fender/mud guard. It also has a non-symetric tread pattern which we HIGHLY recommend against on the single rear wheel Spyder. It does have asymmetric forces when it hydroplanes and can push the rear of the spyder to one side. Its NOT recommended at all.
    Speak for yourself, you are not the community spokesperson or expert.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2017
    Clovis, CA
    Sorry to highjack this but, does anyone know the UTQG rating of the stock rear kenda? I’m currently running the kumho ecsta & it sucks for traction. I was thinking of going to the Pirelli P Zero but like jcthorne said it’s not directional. I’m probably going to go back to the kenda for traction unless anyone else has a recommendation. I do not care about tire life. I would rather change it out more often than loose traction.
    2015 F3S-T , Black Black & Black
    Mar 2019
    VAN VLECK TEXAS
    Just put the Yokohama S-Drive 205/55. /15 on my 2018 F3-T. Fits great seams to have lots of traction. Mid April going on a 5000 mile trip to give it a good work out.
    Sep 2013
    Houston
    I can tell you the Yoko S-Drive has considerably better dry traction than the Kenda. It also does really well in the rain. As a side benifit of it being well made, it does not prematurely wear out down the center and you will get 15 to 18k miles out of one.
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    With respect to all concerned, if you have a tire "wearing out down the centre" this indicates over-inflation.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    Sep 2013
    Houston
    Quote Originally Posted by Smokes View Post
    No, on the poorly constructed weak wristed Kenda tires, they wear in the center because the tread area is not properly supported by the tire's internal construction. The tire balloons at speed and rides only on the center of the tread. Its truly an awful tire. Its NOT over inflated.
    Nov 2012
    North Las Vegas, NV
    Oh Boy!
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    I’ve got a few thousand miles on the Michelin Defender T&H 205 60 R15 on my 2016 F3LTD. And I’m not posting to take any sides here, just personal experience.
    1. The tire fits fine.
    2. It is very comfortable
    3. I run 19/20 lbs of air
    4. Handles great
    5. I have not ridden in the rain with it so no comment.
    I’ve also had the Yokahama S drive and loved the tire but it wore out too quickly so I’m trying the Michelin.
    2016 F3L , Big Bike Parts Black
    Jan 2019
    Alcamo- Sicilia -italia
    I am already at my second toyo r 888 r and I am fine, of course it consumes quickly, but to me this does not interest.
