Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Nov 2020
    OR
    Quote Originally Posted by Eckhard View Post
    PM me your email and Ill send you the instructions.
    Can you email them please
    mikef@functionalfoto.com
    Much appreciated in advance - Thank You
  2. #27
    Oct 2021
    MI - Michigan
    Hello I know this tread is old but can someone please send me the instructions on install for a 2012 RT Limited?.
  3. #28
    May 2018
    Chateauguay, Qc, Canada
    PM me your email address and I'll send out the docs I have sent to several other people.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
  4. #29
    Mar 2019
    NEBRASKA
    Email me dvuch1@msn.com and I private messaged you on this forum
    2012 RTL 14 RTS , Pearl White @ Pearl White
  5. #30
    Dec 2015
    Oakley Utah
    Ignore this post.
    2014 RTL Platinum
  6. #31
    Apr 2019
    Clinton, MS
    [QUOTE=UtahPete;1633972]I've posted the instructions here https://www.spyderlovers.com/forums/...p?albumid=5243
    The first pdf is the one from Can-Am. The second is from a former contributor here on SpyderLovers showing how he went about it.[/QUOTE
    The thumbnails are there but the full size files don't come up. Hopefully it is just me.
  7. #32
    Dec 2015
    Oakley Utah
    Ignore this post. See post #38 instead.
    2014 RTL Platinum
  8. #33
    Dec 2015
    Oakley Utah
    Ignore this post. See post # 38
    2014 RTL Platinum
  9. #34
    Sep 2014
    USA
    Dec 2013
    I think I need some help from a moderator getting a pdf to download to a place where others can access it. The problem with 'albums' is it only accepts .jpg files apparently.
    You can upload PDF's to a new post in this thread via Manage Attachments.
    Go to Reply to Thread; then Go Advanced; and once the screen paints up scroll down past the text entry field & the Additional Options immediately below it, until you reach Attachments. Click on the Manage Attachments button, & then when the new Manage Attachments screen paints up, click on either Choose File under Upload Files from your Computer & go thru the selection process before clicking on Upload in the bottom right of that box; or enter the URL in the top field under Upload Files from a Website. Once your file is uploaded, it will appear in the box immediately above the Attachment Key field which shows all the acceptable file types & their max sizes, & once your file is shown there, you can go back to the Reply to Thread screen & fill in any necessary text (at least a quick description of what the attachment is/does/is about would help! ) and then click on Preview Post or Submit Reply as you desire - repeat as necessary!
    Please Note: While the software might allow you to upload anything up to 10 files per post this way, just use the next line in the applicable section or you'll over-write anything previously uploaded; but if you want everyone to be able to see it/them, you should try to limit the numer of attachments/images to any one post to about 5, as (depending upon size & maybe other stuff) anything much more than 5 attachments/images on any one post may make it impossible for some potential viewers on small screen or low capacity devices/networks to even open the thread! . So if you want to ensure everybody who wants to can see your post & its attachments, Please, no more than 5 attachments/images to any one post. . If you have more attachments/images that you wish to upload, simply upload the first 5 to one post, submit that, then attach the next lot (of up to 5) to another/the next post (& repeat as necessary! ) Doing that will not only make it possible for the vast majority of potential viewers to actually open the thread & see your posts with their attachments, but it will also allow for an easier read & the display of a larger number if you have them - jam too many attachments/images into one post & even those who CAN open the thread are less likely to read/view it all, while posts of up to 5 attachments will break it up into readable/viewable chunks more likely to reach a wider audience!
    Over to you!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  11. #36
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    Can you even get these vent kits anymore?
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
  12. #37
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    Still available on Amazon and ebay.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  13. #38
    Dec 2015
    Oakley Utah
    Default Two PDFs explaining how to install the RT Vent kit
    One is from Can-Am. The other is from a former member here on SL.
    Thanks Peter Aawen for the great instructions on how to post PDF files.
    Attached Files Attached Files
    2014 RTL Platinum
  14. #39
    Sep 2017
    Wa.
    Call your spyder dealer. Have them see if they still have the kit or they can get it for you an have it sent to your home. My dealer had it to me within a week at my home. Still only cost around $70. It was couple yrs ago that I got it. Maybe still possible to get it from dealer. It was a lot cheaper than what I could find online.
  15. #40
    Aug 2022
    PA
    Default Know it’s an old thread, but struggling to find instructions.
    Afternoon all, first post.
    Looking for a full copy of install instructions for the RT vent kit. Any and all help appreciated.
    Thanks
    DC
  16. #41
    Sep 2017
    Durham,Maine
    Go up to post 38 and click on the thumb nail, you'll get what I think your looking for!!
    2012 RTL , Pearl
  17. #42
    Aug 2023
    VA
    Default install for vent kit
    do you happen still happen to have the install instructions?
  18. #43
    May 2018
    Yes, still got them. Pls PM me your email and Ill send you the instructions.
    Eckhard
    Spyder RT Ltd, 2011
