Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 56
  1. #26
    Apr 2017
    North Central Florida
    Quote Originally Posted by FINFAN3DP View Post
    And for all the people that are saying just add something, or what do you care cuz it doesn't work well anyway, please don't respond.
    EVERYBODY who has posted in this thread is trying to help as best they can.
    YOU being nasty about it doesn't accomplish anything and doesn't bode well for future questions you might need help with.
    P.S. "Forums like this" are not designed to relieve you from your simple responsibilities in life.
    Buck it up.
  2. #27
    Nov 2012
    North Las Vegas, NV
    The elapsed time thing would be under the Trip A or B function using the mode button.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  3. #28
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Is there an ignore feature then? Cuz that way i wont have to read stuff from people that arent answering questions?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
  4. #29
    Nov 2012
    North Las Vegas, NV
    If you click on their name, click on view profile, on the list you will find the ignore function.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
  5. #30
    Apr 2017
    That button works both ways.
    What if nobody sees YOUR posts anymore ??
  6. #31
    Dec 2015
    Oakley Utah
    That would literally be 99.9% of the forum. Good luck with that!
    Besides, by definition you are already not reading stuff from people that aren't posting (i.e. answering questions).
    2014 RTL Platinum
  7. #32
    Nov 2015
    Chardon, OH
    Could be the trip elapsed time option.
    That's what it is doing, but I can't find how to change it to strictly a clock.
    I apologize in advance, but I just have to ask this FINFAN3DP. Are we looking at the blue circled clock or the red circled clock?
    Doug
    ”Freedom is not a loophole”
  8. #33
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Snowbelt Spyder View Post
    Excellent question.
    2014 RTL Platinum
  9. #34
    Mar 2015
    forrest above Reno, Nv
    Hi Guys,
    The blue circle is the time ( too small to be of any use ). The red is elapse time of the trip I believe. It resets whentrip meter is reset , which I do at every fuel fill.
    Lew L
    2014 RTS , Circuit Yellow
  10. #35
    Nov 2015
    Chardon, OH
    That’s exactly why I asked, Lew. To confirm with the OP which clock he is talking about with this thread, making sure we’re all talking about the same clock.
    Doug
  11. #36
    Jun 2018
    HAYMARKET,VA
    Thanks! This is going to make this forum much more helpful!
    Baja Ron Sway Bar
    Key Cover from Ebay
  12. #37
    Jun 2018
    HAYMARKET,VA
    Doug,
    I'm talking about the blue circled one.... I actually got it to stay today, even after shutting it off. It seems like if you put it on the 24hr clock it will not keep time (no, i'm not getting on the bike at midnight every day! ), it just reverts to 00:00 every time you start the bike. But, when I chose AM/PM it seems to have kept it, even after shutting the bike off for 15 minutes. I will try it again tomorrow and see if it kept it over night.
    Hopefully this is the end of this issue. Now to move that stuff from the trunk to where it will be usable.
    Baja Ron Sway Bar
    Key Cover from Ebay
  13. #38
    Nov 2015
    Chardon, OH
    FIN. That’s good. Because the only function of that clock is time of day. And the only thing that should cause it to reset is a loss of battery power. And even then, I’ve had my battery out overnight and it kept time. I don’t use 24hr format so can’t vouch for that. As a long shot, if you wanted, next time you start up and while you’re waiting to warm up, cycle through every one of your preference settings, change them or adjust them and change them back, in order to rewrite all those settings back into memory. If the problem continues I’d focus on exactly when it resets. That is, when they key is turned on, when the start button is pushed, etc. What happens to cause it. Good luck with it.
    Doug
  14. #39
    Jun 2018
    HAYMARKET,VA
    Thanks Doug!
    Baja Ron Sway Bar
    Key Cover from Ebay
  15. #40
    Jun 2017
    Crossville TN
    Like Doc Here
    We just ride I look at the clock just for an estimate of the time. Ours like most is always off. The kids will call if something important comes up
    Dave
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
  16. #41
    Jun 2018
    HAYMARKET,VA
    Nope, right back to all zeros.... Very frustrating.
    Baja Ron Sway Bar
    Key Cover from Ebay
  17. #42
    Apr 2017
    It should now be obvious by now that nobody in this forum can help you with this, possibly because of insufficient facts.
    You NEED to either take it to a dealer OR stop worrying about it.
    A small piece of masking or black electrical tape can help with the ignoring part.
  18. #43
    Mar 2015
    Did you happen to check for good tight battery connections???
    PS: Isn't the " ignore" list GREAT.
    Lew L
  19. #44
    Nov 2016
    Upstate NY
    Please check the fuse F1 in the right fuse box. It is the power for the clock. The right fuse box is actually on the left when you are standing in front of the bike looking in the frunk. Fuse F1 is the first small fuse. 15A. This fuse also goes to the hazard lights. If your hazards dont work, then the fuse is blown. Hope its that simple.
    2021 Sea to Sky RT , Highland green
  20. #45
    Jun 2018
    HAYMARKET,VA
    Hi Joel,
    Thanks for that, but unfortunately that fuse is ok, even tried another one, still didn't work. HOWEVER, i never set the date before, so I did that this time. I will check the byke again tomorrow to see if it saved the time. FINALLY, maybe I have the fix.
    PS, i checked the manual and called the dealer, no one knows why it is doing this, so I'm hopeful the date issue fixes it.
    Baja Ron Sway Bar
    Key Cover from Ebay
  21. #46
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
  22. #47
    Jun 2018
    HAYMARKET,VA
    NO SUCH LUCK. Still went back to zeros. UGH!!!
    Baja Ron Sway Bar
    Key Cover from Ebay
  23. #48
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Lew L View Post
    Lew L
    Yeah, checked them while I was in checking the fuse. Tight, no corrosion. AND YES, thanks!! The ignore feature is AWESOME!!!
    Baja Ron Sway Bar
    Key Cover from Ebay
  24. #49
    Idaho
    Deleted text. Accidental double post.
    2014 Copper RTS
  25. #50
    Idaho
    There are two fuses feeding power to the cluster, F1 and F7 in the left box. Have you checked both? F1 provides power full time. F7 when the ignition is on. Check all your preference settings. Are any of them not sticking when you turn the ignition off? IIRC there is at least one, maybe audio related, that reverts to default when the power to the cluster is cut off. Do the hazard flashers work when the key is off? F1 is listed as both cluster and hazard but F2 in the RFB is the main hazard power. I don't know but the flashers may not work if F1, LFB is blown.
    If you have established that the cluster is getting power all the time through F1 then the only thing I can see is there is a short or break in the circuitry inside the cluster.
    2014 Copper RTS
