Results 1 to 16 of 16
Thread: White key
    May 2016
    Noblesville, Indiana
    Default White key
    Anyone else think the white key looks a little funky on a black bike? Half tempted to paint it.
    Active Member QuasiMotard's Avatar
    Jan 2019
    Houston, TX
    Quote Originally Posted by SpyderUSA View Post
    Anyone else think the white key looks a little funky on a black bike? Half tempted the paint it.
    Hah, I had the exact same thought. White just doesn't match the aesthetics of the beast. I also don't like the no keyring hole issue. I know that they have the ball mount for your key ring, but it just seems too flimsy to me. I'm just not accustomed to having a watercraft/snowmobile key for a street bike. ;-)
    I was thinking about trying a couple of different options on mine:
    1. The whole back end of the key (opposite the claw) could be shoved into some heavy-duty heat-shrink tubing (black or whatever color you prefer). Apply a little heat (not too much) and voila... you have a ruggedized black key. The end of the heat-shrink can be cut to your desired length, heated up a bit and then flattened out. Punch a hole in the end of the flat part for your key fob, short lanyard, or whatever else suits your fancy.
    2. Wrap the "neck" of the key with some thin, high-strength cordage like Lash-It or Zing-It (Dyneema, Amsteel, etc) to create your own lanyard or whatever to give more girth and purchase to the plastic.
    In either of those cases, the lanyard, key fob, or keyring option would need to be low profile and not get snagged by your leg or flap around in the breeze. Both of those options are also reversible if you change your mind.
    I'm used to having closed leather fobs on all of my bikes to bind multiple keys together and to keep them from scratching the triple-tree. Ryker owners that opt for the saddlebag/pannier case will also have an extra key to manage... no easy way to keep them together with the current key design.
    QM
    Default Hang in there....
    Many did not like the sheath holder for the spyders and in short order the aftermarket guys came up with a lot of solutions. As for the color....well paint is cheap but there are other ways but I'm not carzy about its location anyway. Not to worry though... I don't have one...
    ​2012 RS sm5
    Bossier LoUiSiAna
    Quote Originally Posted by QuasiMotard View Post
    QM
    Good fold of leather stitched together should work nicely, wonder if BRP will offer to new owners again?IMG_3521.JPG
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Member watertowerman's Avatar
    Dec 2018
    Welch Ski Area, MN
    You can take the fob off when it is running. It is needed only to start it. Check the ryker manual.
    May 2016
    You're exactly right and that is probly going to be my solution. Is the radio signal of this fob strong enough that you can simply leave it in your pocket and start the byke? I haven't tried that.
    Jan 2019
    Houston, TX
    Quote Originally Posted by watertowerman View Post
    Yep, I noticed that in the manual. That might become a new habit, just so I don't leave accidentally leave it on the bike. It's just odd to me to use that type of key on a road vehicle. I feel like I'm getting on my SeaDoo GTX, but the plug isn't on the bars and the floatie/tether is missing. ;-) It's just a new habit to learn... I'll adjust.
    Quote Originally Posted by RykerUSA View Post
    That would be ideal, so it behaves similar to any recent keyless automobile. Sadly, I'm not with my Ryker to test the theory. My suspicion is that it is a near-proximity RFID chip that needs to be powered by an inductor/transducer in the post. Automotive keyless fobs are self-powered with a battery and use slightly higher power to operate/communicate up to ~30 feet from the vehicle.
    QM
    May 2016
    Well, I just couldn't take it anymore. I painted that white key gloss black and now I can sleep much more comfortably knowing that the key does not stand out like a sore thumb on the side of my tricycle. Life is once again good.
    Apr 2017
    North Central Florida
    If you ever walk away and LEAVE it in the ignition.......because it did NOT stick out like a sore thumb......you might change your mind.
    May 2016
    I consider that before taking this big step. However, even with the key IN, I don't think anybody could figure out how to start the thing!
    Idaho
    Except those who have already stolen one!
    2014 Copper RTS
    Jul 2008
    Natchez, Ms
    I have always used Lamont’s Key knob and no one ever realized it was the actual key!
    Replaced my Lamonster Certified RT Limited #1874 With a 2018 RTL.
    Idaho
    Quote Originally Posted by Jester View Post
    You're referring to his In Plain Sight key knob, right? The Ryker doesn't use a key, just a fob that slips over a small plastic knob.
    2014 Copper RTS
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I think I was more surprised about where the key--fob--knob grabber-- etc.. went, than what color it was.
    2019 Ryler Rally , Shock Yellow
    Feb 2019
    England
    Hi all painted my key RED to match panels + top of parking brake Nico75
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Has to be attached to start. Then you can remove it if you want to.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
