Results 1 to 19 of 19
    Apr 2015
    Green Bay, WI
    Default suggestions for a secure mount on rear rack
    I'm attempting to mount a rear rack on a 2015 F3's rear backrest post. I'm using leftover Harley chrome post mounts on the backrest. I want to add support via 5/16" stainless steel rods pushing up on the rack. I have a mount location on the F3's but using hose clamps to secure the ss 5/16" post to the rack isn't adequate. anyone have any ideas--description of a sold secure bracket I could use? I plan on carrying a 15 lb small suitcase on the rear rack.
    Thanks,
    Close up rear rack.jpgHarley clamps to backrest posts.jpgMount for rear rack.jpg
    Apr 2015
    Green Bay, WI
    Too Late--I'm committed to a successful installation.........Plus I can't find a compatible rack for a 2015 f3's that has a passenger backrest. Do you know of any in Utah--Pete ??
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Wildrice,
    I have that rack mounted on the backrest the same way without any supports. I have a topcase mounted to it and I carry more than 15# and I have no problems.
    2020 RT Limited , Petrol Blue
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Wildrice View Post
    Sorry, I don't. But I haven't looked for one either. Good luck.
    2014 RTL Platinum
    Apr 2015
    Green Bay, WI
    Wow---I wasn't sure the backrest posts could handle it but your rack is mounted higher than mine which places more stress on the passenger backrest--yet you don't have any problems. I'll consider that after I fail to find a suitable bracket to secure the stainless steel post to the rack. Thanks again.
    Darrell
    Apr 2015
    Green Bay, WI
    I have looked--google searched--zero results with the passenger backrest on the F3's Spyder. Pete--You just don't appreciate a "Work of Art" :-)
    Darrell
    Dec 2015
    Oakley Utah
    I have looked--google searched--zero results with the passenger backrest on the F3's Spyder. Pete--You just don't appreciate a "Work of Art" :-) Darrell
    Ah, got it. Where does your support strut attach at the top and bottom?
    For these kinds of projects, I favor using aluminum because it comes in a variety of forms and is very easy to work with. I think it would make for a cleaner stronger installation.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    I'm attempting to mount a rear rack on a 2015 F3's rear backrest post. I want to add support via 5/16" stainless steel rods pushing up on the rack. I have a mount location on the F3's but using hose clamps to secure the ss 5/16" post to the rack isn't adequate. anyone have any ideas--description of a sold secure bracket I could use? I plan on carrying a 15 lb small suitcase on the rear rack.Thanks,
    I would use some 1/4" x 1" angle aluminum instead of the SS strut. That will give you a flat surface to flat surface interface at the rack enabling you to bolt (1/4-20 SS screw with nylon insert locking nut) the strut to the rack. I'm not sure how you would secure the bike end of the strut, but aluminum is easy enough to find and work with that I'm sure you can figure something out.
    2014 RTL Platinum
    Member Outlander's Avatar
    Nov 2017
    Usa
    Darrell
    CanAmSpyderAccessories.com
    Good information about backrests.
    Sep 2015
    Cold Spring, MN
    Darrell
    I had to mount it high and angled down slightly so I can open the top case.
    Think about the pressure the passenger puts against the backrest, that's much greater than the 15+ pounds you want to put on your rack.
    Trust me, it's no problem! We've used ours on an off for 2 years and it works great.
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Outlander View Post
    Those only work with the F3T & F3 Limited. I have a 2015 F3's.
    But "Michaelscs" idea was Excellent.
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Michaelscs View Post
    I thought it over & You are correct---the passenger backrest is very sturdy for my needs--Big Thank You again. Darrell
    Apr 2015
    Green Bay, WI
    I looked it over & "Michaelscs" was right. I don't need a support strut. thanks anyway--Darrell
    Nov 2017
    Usa
    This one
    Apr 2015
    Green Bay, WI
    This one
    I used old Harley heavy duty chrome strut clamps to the passenger seat posts.Harley HD strut clamps.jpg
    Apr 2015
    Green Bay, WI
    This one
    Thanks for the tip but I only want to use the rack when I need to carry a small suitcase or maybe bungee a 12 pack--groceries back from the grocery store, etc. The majority of the time the rack will be empty thus appearance has a value to me. I like the look of my completed rear rack project--it is very sturdy.
    Darrell
    Bossier LoUiSiAna
    IMG_9065.jpg game on
    Sep 2015
    Cold Spring, MN
    Looks good Darrell!
