Results 1 to 6 of 6
    Oct 2015
    Default Brake failier light comes
    The brake fail light and parking light come on but brakes and parking work fine
    Active Member wd8ajj's Avatar
    Las Cruces NM
    Had that happen on my 14 and found out that the brake fluid was down a bit. Topped off and never had the light come back on.
    May 2017
    Mesa, Arid-Zone-A
    It only takes a couple teaspoon of fluid to cause the Brake Failure indicator to go off. Try topping it off (but not too much).
    Semper Fi
    Active Member ndspyderlover's Avatar
    Dec 2012
    fargo, north dakota
    Quote Originally Posted by mrpeeps240 View Post
    Top off the brake fluid with an eye dropper or I use a turkey baster. It won't take much brake fluid to top it off
    Nov 2017
    San Francisco Bay area
    I just use the cap from the brake fluid bottle although I do worry about dropping it in the reservoir. As others have said the Spyder is really sensitive to the level. If I was a little low the light wouldn?t go on until I was pointed downhill, not by a lot either, then it would blink and the parking brake would not hold even though foot brake was fine. As others have said add a few capfuls or teaspoons or whatever but don’t over fill either. The brake pedal should feel firmer afterwards when you ride and you should feel it rise against your foot when you release the parking brake.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Default Little checking.....
    There are several reasons for the warning lights ... worn down pads, brake light switch, fluid level, brake light bulbs, ryding with your foot on the brake but fluid seems to be the most common....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
