Rear cargo hatch will not close
So I installed a rear cargo tail light from custom dynamics on my 2017 Spyder RT. All went well, works great, but after putting everything back together, the rear cargo hatch will not latch. I took the upper fender trim panel off again and it latches just fine, I put the panel back on and it will not close. I tried adjusting position a bit but it made no difference. Any suggestions?
I hear that there is a good dealer near Tampa.
I bet they could help.
you have to make sure the tabs all the way
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
What samewok said. I'll bet you don't have the tabs properly seated.
SpyderLovers Sponsor
In the top center of the trunk is a tab that fits in a slot. Remove back panel, see if you managed to wad that tab up. If it is ok, make certain the tab is all the way in, and the painted piece is flush. If it still gives you fits, call me. Number below. Joe
Joe Meyer
Thanks for this post. Helps should I ever encounter a similar problem
Tags for this Thread
