Winter storage: remove air bag pressure?
Any logic to doing this? Spyder in a heated garage until spring time..2015 RT SE
I’m interested in this as well
Great question and one that I am interested in as well....
2016 RT-Ltd
Bajaron swaybar
Spyderpops trunk light
Elka stage 2 front shocks
Extra longbrake pedal
brake modulator
Centramatic wheel balancers on the front and rear.
Rivco dual flag holder
Tricled mirror turn signal indicators
with American and Texas flags
Lamonster Magic Mirrors
missing belt guard
Lambskin seat cover from Smokey mountain sheepskin.com
Tricled 360 degree led Headlights
Lamonster led fog lights
Baker air wings
2019 Silverado Duramax dually
2019 Cyclone 4007 toyhauler
Spyderpops bumpskid w led light
Rivco brand footrest
spydermanexhaust.com exhaust
had my exhaust installed @ Spyder in the hills.
Don't do it!
Just make sure the blinker fluid is topped off, and the piston return springs are well-oiled.
... heated garage here as well, but hoping to take it out for a ryde few times a month when it's dry out.
Holy crap I better go check these and buy some driveshaft fluid!
Don't forget to change the air in the tires to winter season!
http://kalecoauto.com/index.php?main...9VDkFHPlsqDYp0
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
It helps to turn the drive belt inside out for winter too.....reduces memory in it
2021 RT Limited
Replace
Oh, and please don't forget to oil the muffler bearings. Wouldn't want them to seize up over winter.
I don't see any advantage to doing that, but then my idea of winter prep is filling all the bikes tanks with aviation gasoline and plugging in the battery tenders. Sunny day in January? Check tire pressure and take a ride providing roads aren't salted heavily. Never had a starting issue in the spring.
storage for the winter
I SpyderMan
BRP recommends placing a battery maintenance charger, and covering it with a breathable cloth and these all, me it is in an unheated garage.
FlyBoy2121
There's no need to zero the pressure in the airbag.
But if you do: make SURE that you don't let the rear suspension collapse down fully: put your bike up on jackstands.
Dont do it ...this is from experience my 2012 RT compressor went out and I only found out when riding we were bottoming out when we hit bumps and I tried to put more pressure in the rear air bag suspension but could not, what I found out was that all the air had leaked out of the airbag and the compressor was shot. It was repaired under warranty but the tech told me that at all times there must be air pressure in the bag due to what happened to mine as the air bag collapses into it self and causes very small cracks which then leak. So the airbag MUST have pressure in it at all times I would go up to my workshop were the RT is stored during winter and check that there is pressure in it and would never let it get below 15 psi normally it would take about a month before I would need to add in some pressure to it.
2017 RT Limited
May get a chance to ride if the sun is out
Bike washed and a coat of wax - CHECK
Tank full of gas with fuel stabilizer - CHECK
Fresh oil change (also just changed the HCM filter) - CHECK
Winter air pressure checked (left the 30 psi in the fronts after new tires.. sure rolls around the garage good) - CHECK
Looking online for some new farkles, heated gear - CHECK
Battery tender ready on the shelf - CHECK
If it warms up a little, roll it out and go for a spin, watch for loose gravel - CHECK
Reason: bat tender
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
don't forget the wiper fluid either. The old stuff gets stale over the winter
you mean they actually salt the roads in Ohio. Must be something new.
Well I remove my belt on my can-am skidoo, maybe I should do it on my can-am spyder too?
LOL, I know a lot of people who do the same. I never did, and didn't ever wish I had.....No more sled for us though....It just doesn't snow enough around here anymore.
2021 RT Limited
