Results 1 to 5 of 5
    Jan 2015
    southern WI
    Default 1330 Hex oil drain plugs
    Where can I buy the hex style oil drain plugs for the 1330 RT? Mine are still ok, but I'd like to swap em out next oil change.
    2021 RT Limited
    2016 RTS , Pearl White
    Mar 2013
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jan 2015
    southern WI
    Quote Originally Posted by PW2013STL View Post
    Thanks....that's the left side, one, do ya by chance have a link to the right side one?
    2021 RT Limited
    Mar 2013
    Quote Originally Posted by Mazo EMS2 View Post
    They do carry both.
    Transmission
    Gold Plug Magnetic Drain Plug MP-01
    12mm Stainless Steel Magnetic Drain Plug.
    Pulls metal particles from your oil.
    Uses Extra Washer SW-03 for future oil changes.
    $18.99
    Engine
    Can-Am 1330 ACE Engine Magnetic Drain Plug – MP-18
    Solid Stainless Steel. Proudly Made in the USA!
    Eliminate the internal Torx head and get a real External Hex Head! 15mm Hex Head! No more stripped plugs! Make your next oil change easier!
    Replaces OEM Part # 420441681. Includes Aluminum Washer 420430623, but not the O-rings. Just re-use the stock.
    $20.99
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Default Thread: uh oh stripped drain plug
    Did a little research on replacement plugs. Please read this thread on some problems spyder owners encountered. Something to think about before we use these.
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
