Spyderpops rear lighting kit for RT - strobe question
Does anyone have the 4 piece rear lighting brake/run/turn kit from spyderpops? Here is the link: https://spyderpops.com/rt-brt-rear-l...g-n-play-easy/
I had it installed, and noticed the strobe brake function doesn't seem to be a full strobe, i.e. the right section will flash then the left section will flash, and I was under the impression (mistakenly perhaps) that the entire thing, all 4 sections would flash at the same time when the brake was pressed.
Long story, but I don't have a video of it, nor do I have the spyder with me now to take a video of it. I only saw it for a short period of time, but was hoping someone who has the same one can help me out. Is that normal?
Thanks in advance,
Mike
2016 RTL "Boris"
Foam Grips
Utopia Backrest
BRP Passenger armrests
Bajaron sway bar
LED Bumpskid w/remote
Belt guard
BRT rear lighting w/strobe
High mount BRT w/strobe
Dual a-arm LEDs w/turn signals
Multicolor underground Halo lighting
LED headlights and foglights
FOBO TPMS
Techgripper phone holder
Lidlox
Dual USB with voltmeter
Dakota Digital Compass/Clock/Altimeter/Temperature Gauge
Vredestein Quatrac 5 175/55R15 - Fronts
General Altimax RT43 215/60R15 - Rear
Call Spyderpops and ask him. (not sure which setup you have)
Cruzr Joe
sounds like wig -wag
and by that I mean " wig -wag " like on official autos ( police cars , ambulance , fire truck ) they flash opposite each other , ( looking at the instruction sheet I have , as I never put the lights on , over 2 years now , well time flies when you are riding spyders .... looking at the instructions , " plug in harness to the harness for the tail lights and then plug in the l-e-d`s from bottom 3 strips , now plug in tail lights and put them back as before , ( I guess they mean before we take the cycle apart and loose 2 bolts or screws , and for get to reinstall the tabs )and the last l-e-d is up too the top and easy to gain access , for the last l-e-d bar on the top case ... this is from the spy 184 r-t brake run turn lights with strobe ... it doesn`t mention the function of the strobe ... I will check the video division for more information if I see something I will check back in ...
hahahaha think i see
here is a video I do remember looking at around 2 years ago , and you can see why I decided to go riding https://youtu.be/Llv-EKtBGOA this is pretty much how the lights will install , my not be spyder pops , but the connections will be the same , now I wonder if there are 2 different styles of lights , the wig/wag type as in above reply , and the all on at the same time type ? ( time to give spyder pop a call and double check , from others who have contacted any spyder aftermarket things , seem to be happy at the end product , or so from the replies I have read ) probably will get a 2nd set and ship back 1st set type thing ? will not hurt to find out ... or just leave them , as you are not in back looking while driving ...
I have installed several sets of these and they do not wig wag. They strobe in unison.
Some of the units are defective. Mine was and Spyderpops sent me a replacement. It was just the left side harness on mine. Call him.
2017 F3 Limited
Thanks everyone for the replies. Since my Spyder is at the shop 3 hours away, and they're closed today and tomorrow, I was hoping someone might have a video of the light "strobing" so I can email to them to compare.
I do have the spy184 from spyderpops - link is in the original post. I don't necessarily mind if it's not in unison, but I want to make sure it's not defective.
I will call or email spyderpops today.
Mike
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
thanks j.c.
I wasn`t sure , I see some on sport 2 wheelers that flash like wig/wags . so I wasn`t total sure if there were 2 different sets
I also recently installed these lights, albeit on my F3-S. The back and forth flashing between sides is definitely not normal. Mine all come on at the same time.
Have you gone through the "hyper flash" process to reset the light timings? If not, try that, and see if it helps. If so, sounds like you have a defective set and should get them back to the seller.
Thanks, I will mention it to the technician tomorrow. I'm hoping it's something simple!
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
Pops will take care of you
Call Spyder Pops, he will take care of your problem like no one else I have every done business with. He knows the value of good customer relations.
I already got in touch with spyderpops, he said what thought - that the lights should flash in unison. I'm hoping it was just my eyes, and i'll find out tomorrow when i see a video of it
Mike
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
Ok, hopefully this works :
https://youtu.be/awcgI5yfHqA
I already asked spyderpops, but if someone can tell me if this is normal strobe or not. Just wasn't 100% sure if that's the way it's supposed to blink, looking like right to left. Thanks.
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
video
That is NOT how mine works, mine was installed at Lamonster garage by Spyderpops crew........
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is " Purl"
Mine too. They should all flash in sync with each other.
Have you tried the reset/sync process that came with the lights? If not, try it to see if it fixes the timing issue. If so, get a new set from the vendor.
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
Originally Posted by ludwig12of45
I tried hyperflash reset and it didn't work.
Harvey from Spyderpops said it's not normal and replacing the left harness should fix it. He's sending me a new one
Now I just need to figure out how to replace it
Glad they are providing you a new one!
Well, the new harness came in today. I followed the instructions, replaced the harness, which was easy to do since it was already there and saw how it was. Unfortunately I have the same issue. I don't know what else to do at this point. I emailed spyderpops so we'll see what the next steps are. Ugh
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
This is how I set up brake lights to flash. I left the LED strips to just be normal running/brake lights and made it so the Spyder tail/brake lights do the 4 second flashing.
https://youtu.be/GkXAxTiKRS4
Thanks for posting the video. How did you change the LEDs to stop strobing?
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
You might have the LED strips connected AFTER the brake strobe unit and that's why all the lights flicker. Make LED strip connections first, then make brake strobe connection. Looks like the LED strips blink in conjunction with the turn signals and the brake strobe should only work the main brake lights. If I had problems I'd be calling Spyderpops. I had to for my install and TricLED really helped me figure it out.
I'm actually using TricLED strips and brake flasher.
Spyderpops asked me the same thing - if the high mount light is before or after the brake run turn harness. since i had the dealer do it, i have no idea so i'm waiting to hear back from them.
2016 RTL "Boris"
Foam Grips
Utopia Backrest
Bajaron sway bar
Belt guard
FOBO TPMS
Lidlox
